Kết quả 1 tới 10 của 10
    Thành viên mới nguyenphong.vb's Avatar
    Feb 2012
    Mặc định 2700 len nokia trang man roi tat
    em co con 2700 len nokia rui trang man va tat. chay v9.98 ko dc mong ae giup.
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 17D967DF
    Verifying communication to device OK.
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.562 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.563 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.140 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.407 s
    CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 13.891 s
    CMT FLASH,NOR area [01380000-0151FFFF] erased in 6.875 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 37.094 s
    Processing PPM file: rm561__09.98.ppm_mr
    [BB5,BB5 ALGORITHM] size: 6.53 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF] erased in 35.969 s
    Programming completed in 32.704 s
    file rm561__09.98.image_mr_red is empty, skipped.
    Total time for flashing process(boot+erase+write) was 4 min 27.610 s
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
    Market items is empty, please select the correct products path !
    Chú ý: viết tiếng Việt có dấu nha bạn
    Apr 2010
    anh tìm cái file khác chạy xem sau..theo em mấy thằng này bị CPU tầng là 100% em đã làm mấy cây rồi anh ơi kết cuộc là trả máy lại thôi bị tình trạng như cũ...này hay main mới hết mà hi hi hi
    Thành viên tích cực ATmobile_qn's Avatar
    Aug 2011
    Tải bản cao nhất về chạy thử bạn. Không được múc bằng phoenix
    Yahoo:thanhtruyenmobile ĐT: 0989 413 413
    Thành viên chính thức THẢO-GSM's Avatar
    Dec 2010
    v full đánh đi không đc đá nhà lầu phát không đc tháo ra đóng lại lun chắc ok không thì thay cặp thui bạn
    bạn có những thiết bị gì. nếu có MX thì backup full rồi chạy lại coi
    Jan 2012
    Trích Được post bởi quangduan Xem bài viết
    làm theo bác này done ok đừng thay cặp vội
    Buôn Ma Thuột City.
    Đúng rồi đó ,bạn backup xóa full rồi chạy lại cho em nó coi sao .Not ok thay cặp => Done (Bệnh truyền kiếp của 2700 mà)
    : 0934.80.22.28 .
    Buôn Ma Thuột City.
    Trước khi đụng tới nhà lầu bạn check theo hình dưới trước coi sao nha !!!! Chúc may mắn
    : 0934.80.22.28 .
    Feb 2012
    Mặc định a
    vang e thu xem sao
    Thành viên kỳ cựu phamdienmobile's Avatar
    biên hòa - đồng nai
    Trích Được post bởi nguyenphong.vb Xem bài viết
    Erase size: 21 MB
    CMT NOLO block sent
    CMT KEYS block sent
    CMT DSP0 block sent
    Erase size: 8.62 MB
    hình như bạn flash bằng Nbox phải không bạn ? dùng MX backup full imei lại đi bạn nạp bằng phoenix hay atf xem nói chung thiết bị thì không loại nào giống loại nào mỗi cái có cái hay cái dở nha bạn !
  1. trang tải firmware nokia
    By Tempb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 10-06-2013, 17:29
  2. x6 trang treo nokia
    By tony.haokiet in forum BB5
    Bài viết cuối: 30-12-2012, 12:32
  3. nokia 5200 trang mh
    By giabao in forum BB5
    Bài viết cuối: 06-11-2010, 16:15
  4. CỰC HOT,trang sửa chửa ALL NOKIA
    By HUE_GSM in forum BB5
    Bài viết cuối: 06-05-2009, 17:00
  5. Tặng anh em 1 trang chuyên đề FW Nokia.
    By Phúc_Cần Thơ in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 20-01-2009, 11:07
