bước đầu ae dùng NaviFirmPlus_1.6 để down file
link download NaviFirmPlus_1.6.zip
hình ảnh đính kèm n9 màu trắng 64G
lưu ý ae dùng navnim 1.5 trở xuống sẽ down thiếu file CNT nên khi chạy chỉ chạy có 1 file thôi .phát sinh lỗi không chụp ảnh được ( e đã dính đòn này )
down file xong ae chiến thôi
log chạy
Number of Image Files: 2
Processing Image File :
DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_005-OEM1-958_ARM.bin
CMT Type :
CMT Algorithm :
Secondary Sending Speed : 0Hz
Algorithm Sending Speed : 0Hz
Program Sending Speed : 0Hz
Message Reading Speed : 0Hz
Number of Blocks : 1
Entry Point: 0x003F
Page Format : -1
MAX PAGE : 0x00000580
DFL61_HARMATTAN_30.2012.07-1.SEAP_EMMC_SEAP.bin
CMT Type :
CMT Algorithm :
Entry Point: 0x0019
Page Format : -1
MAX PAGE : 0x76D06400
BB5 MEEGO / HARMATTAN FLASHER
1. Turn OFF Phone and wait 10 Seconds...
2. Connect the USB Cable to the PHONE Micro USB Port
3. Connect the USB Cable to the PC USB Port
TIPS & INFORMATION:
1. To Turn OFF the Phone, PRESS and HOLD the POWER
button for at least 10 Seconds...
2. Battery Charging will still work on "DEAD" Phones.
3. Factory Reset will make Flashing 15 minutes longer
and it will Totally Erase the User Data and Remove
the Phone Lock + Security Code as well...
4. Skip ADL Chk will Cold Flash the Device.
Waiting For Phone on USB PORT/s...
REQUIRED MODE: BOOTLOADER MODE
Sending APE-ALGORITHM: SUCCESSFUL
Nokia Bootloader/PhoNet Found!
SECURE USER DATA ERASING IN PROGRESS
Secure Data Erasing takes about 15 MINUTES...
DO NOT DISCONNECT THE PHONE!!! JUST WAIT...
Estimated Time to Finish Erasing: 23:36:19 (24-h Time Format)
Battery Voltage Test: PASSED
Ready to Flash Images to Device...
Processing Image: cert-sw
Processing Image: cmt-2nd
Processing Image: cmt-algo
Processing Image: cmt-mcusw
Processing Image: xloader
Processing Image: secondary
Processing Image: kernel
Processing Image: rootfs
Processing Image: mmc
All Images were Succssfully Uploaded!
Software Update Done
[]: Found 1 active devices.
[Nokia N900 USB Phonet]: Opening Connection
[Nokia N900 USB Phonet]: Port opened OK!
Rebooting Phone...
Total Flashing Time (Erase + Flashing) : 00:08:27
(Booting time is NOT Included)
Phone is not Connected OR it is not in the
Required Mode...
Reboot the Phone and Enable "PC Suite" Mode
Life timer data is not yet used...
Life timer: ----:--
			 n9 RM-696 Đã Có Tiếng Việt test by ok ATF
