    Thành viên chính thức nguyenlaluong's Avatar
    Mặc định 2700 rơi nước mất nguồn xin giúp thank .
    em mới nhận con 2700 rơi nước , em sấy , lắc CPU thay cặp ic nguồn , bật nguồn lên chữ Nokia mờ mờ rồi treo luân , em chạy phần mềm nhưng vẫn bị thế anh em nào gặp rồi xin giúp thank đây la log của nó:Version from phone: 07.15
    Version from file: 09.96
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08598C8
    Using device: HTI, FW ver: 00.24, SN: 000118A7
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    Reading RPL backup ...
    Reading Phone IDs ...
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    eBB5ProtocolType: OLD
    PUBLIC ID: 09D0001760376850C25B72BB2DDCF3F809034B77
    PRIVATE ID: E4CA4FB6EF4C9BBABFBD2FA1FD9663C4ECED459C
    productData saved.
    Restarting phone ...
    Reading Secure Storage ...
    Reading Important data ...
    Reading SIMLOCK data ...
    Reading CERT data ...
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Flash Imei: 35936003789600
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    SIMLOCK_DATA saved OK
    SIMLOCK_KEY_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    CMLA_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    LOCK120_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35936003789600_BA CK.rpl"
    Processing MCU file: rm561__09.96.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0137FFFF]
    CMT FLASH,NOR area [01380000-0151FFFF]
    erased in 1 min 40.218 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 38.594 s
    Processing PPM file: rm561__09.96.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF]
    erased in 36.141 s
    NOR: OK
    NOR: OK
    Programming completed in 32.079 s
    Processing CNT file: rm561__09.96.image_v_blac
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    NOR page size in the phone is 128 K.
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF]
    CMT FLASH,NOR area [02160000-03FBFFFF]
    erased in 4 min 4.766 s
    NOR: OK
    Converting UCP blocks to 128 K.
    NOR: OK
    Programming completed in 1 min 3.968 s
    Total time for flashing process(boot+erase+write) was 10 min 35.203 s
    Phone type: RM-561 (Nokia 2700 classic)
    SW version: V 09.96 21-05-10 RM-561 (c) Nokia
    Imei plain: 35936003789600-3
    Product code: 0579808
    Battery voltage: 4719 mV, current: 51 mA
    Language Pack:
    - not available.
    SIMLOCK invalid!
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SECURITY_TEST passed
    Failed to read SP data
    sao anh lại làm cpu vội thế dòng này rớt nước anh luộc lại men là ok
    luộc lại mên rồi , chạy cả phần mềm nhưng chi lên chữ nokia mờ mờ rồi treo
    Feb 2011
    thanh hóa
    gia cố lại nhà lầu not ok xây nhà mới
    call :0976 001 628
    Thành viên chính thức kithuatga's Avatar
    Mar 2012
    daklak
    cặp này dẽ mà múc di bạn sài 2 vỉ nhé
    Thành viên tích cực sang_apple's Avatar
    Feb 2012
    F,3 Q4 ,Hồ Chí Minh
    xây nhà lầu mới đi bạn ơi, thật chuẩn nha
    Luôn lắng nghe và học hỏi....
    Moderator TÚ CÒI's Avatar
    hà nội
    SIMLOCK invalid!
    cái này có vấn đề á
  1. 2700 mất nguồn xin giúp ...
    By thaibao113 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 15-10-2012, 19:50
  2. 2700 gọi đi là mất nguồn cần giúp
    By tuyen_mobile1709 in forum BB5
    Trả lời: 17
    Bài viết cuối: 01-09-2012, 13:32
  3. Trả lời: 17
    Bài viết cuối: 02-04-2012, 11:22
  4. 2700 hao nguồn xin giúp
    By 99999 in forum BB5
    Bài viết cuối: 06-03-2012, 20:37
  5. 2700 mất nguồn xin giúp thank
    By nguyenlaluong in forum BB5
    Bài viết cuối: 22-12-2011, 08:43
