Kết quả 1 tới 10 của 13
    Thành viên tích cực Phan29's Avatar
    Oct 2011
    Mặc định Xin giúp 6030 bật nguồn chỉ lên loca model
    log của nó nè ! mấy anh xem roài giúp em với
    Phone type: RM-74 (Nokia 6030)
    SW version: V y3.43 13-09-05 RM-74 (c) Nokia.
    Imei plain: 35706000971629-4
    Imei OTP: 35706000971629
    Product code: 0525021
    Cellular system: GSM
    ASIC ID: 0x2031, type: 2
    Ppm Id: V
    Language Pack:
    English,Vietnamese,Chinese S,Chinese T
    Master code: 2531540044
    Security code: 12345
    Imei net: 35706000971629
    Version: SIMLOCK SERVER VERSION 58
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 8000000000000002
    Oct 2011
    log info bên nbox
    MCU SW : V y3.43 13-09-05 RM-74 (c) Nokia.
    PPM SW : V y3.43 13-09-05 RM74 (c) Nokia. V
    Prd.Code: 0525021
    Bpr.Code: 0519975
    Prod.Sn : MYF279896
    HW Vers : 0601
    UEM : 1314
    UPP : 8241 [2031]
    RFIC Ver: 0500
    DSP Vers: P05w06.v18
    LCD Type: ELBE
    IMEI : 357060-00-971629-4
    SL Conf : 001-01-00000000000
    SL Prof : 800000000000000-2
    SL Var : 00553570600097162900
    SL Aux : 00025555
    HW Sig : 655D6D4C4E473631
    Box Id : 8E7BFFFFFFFFFFFF
    BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    MastCode: 25 31 54 00 44
    Provider: GSM Test Equipment
    #pw+ 158 394 072 625 101 +1#
    #pw+ 825 341 347 335 355 +2#
    #pw+ 354 426 271 216 336 +3#
    #pw+ 714 940 237 261 651 +4#
    #pw+ 458 167 377 643 775 +5#
    #pw+ 058 533 674 677 444 +6#
    #pw+ 039 463 253 716 270 +7#
    V.I.P Lão_Đại's Avatar
    hải phòng
    em này flash wr PM unlock là OK mà bạn
  4. ( Lão_Đại ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Phan29 (10-03-2012)
    Thành viên chính thức kithuatga's Avatar
    Mar 2012
    daklak
    bạn coi lại chân pin di chân bsi bi lỗi rồi...... gỡ bỏ R2205
  6. ( kithuatga ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Phan29 (10-03-2012)
    Mar 2012
    daklak
    không dươc thì làm thế này ok...
    nhớ TK nhé
  8. ( kithuatga ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Phan29 (10-03-2012)
  9. #6
    Thành viên chính thức alohasanh's Avatar
    Tiền Giang
    tháo cái ổ đuôi sạc ra xem sao nhé bạn
    SỐNG ĐƠN GIÃN CHO ĐỜI THANH THẢN
    hasanh80@zing.vn
  10. ( alohasanh ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Phan29 (10-03-2012)
  11. #7
    Vi phạm nội quy manh110983's Avatar
    Mar 2008
    cái này BSI, chân sạc, R2205 hết!
  12. #8
    May 2011
    Hà Nội City
    Thay em này sau đó chạy lại pm là done
  13. ( ĐẶNG BẢO_GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Phan29 (10-03-2012)
  14. #9
    Apr 2010
    làm theo anh đăng bảo là ok thôi ah cần gì nạp pm...đã làm nhiều cây ok
  15. ( KHA_MOBILE67 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Phan29 (10-03-2012)
  16. #10
    Thành viên tích cực VH-Mobile's Avatar
    Đà Lạt
    cái vấn đè này thì bạn xem lại cái chân sạc,và mấy con ụ đằng sau chân pin và con trở đôi ở đường BSI xem sao nha,chúc bạn thành công
    0967-225-468
  17. ( VH-Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Phan29 (10-03-2012)
  1. 6030 không lên nguồn?xjn giúp
    By kechien in forum DCT4 - WD2
    Bài viết cuối: 12-12-2010, 14:34
  2. 6030 kẹp nguồn lên bỏ pin vào ko lên
    By nhoemvocung2 in forum DCT4 - WD2
    Bài viết cuối: 19-08-2010, 14:00
  3. 6030 tự động lên nguồn cần giúp đỡ
    By duong bin bin in forum DCT4 - WD2
    Bài viết cuối: 02-02-2010, 20:56
  4. 6100 lên loca mode
    By voquanghan in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 29-10-2008, 22:46
  5. 6030 kẹp nguồn lên cho pin k lên
    By giaphu_dn in forum DCT4 - WD2
    Bài viết cuối: 01-07-2008, 21:41
