Tình trạng máy mất nguồn , flash lại chỉ được vầy, ae chỉ giúp hướng giải quyết với
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
UEM ID: 00051408A3BDA66
ASIC type: 11
UEM Imei: 35830503181046
Flash Imei: 35830503181046
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35830503181046_BA CK.rpl"
Processing MCU file: rh112_004.030
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
UEM ID: 00051408:2984DA60
Area [01000000-0100FFFF] erased in 0.360 s
Area [01010000-013AFFFF] erased in 20.890 s
Area [013B0000-013EFFFF] erased in 1.469 s
Area [017C0000-017EFFFF] erased in 0.016 s
Area [01FC0000-01FEFFFF] erased in 0.015 s
Flash programming ...
Programming completed in 18.203 s
File Processed in 48.766 s
Processing CNT file: rh1120_nai04.03mr
[DCT4,DCT4 ALGORITHM] size: 110.54 KB
Supported Ids: 2293
Area [01380000-013AFFFF] erased in 1.078 s
Programming completed in 0.875 s
Content extract fail, continue anyway ...
File Processed in 36.453 s
Processing PPM file: rh112_004.03mr
[DCT4,DCT4 ALGORITHM] size: 1.15 MB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 0.359 s
Area [01250000-0137FFFF] erased in 7.281 s
Programming completed in 9.250 s
File Processed in 24.766 s
Total time for flashing process(boot+erase+write) was 1 min 49.985 s
			 1202 cần giúp
 1202 cần giúp
