mình vừa thay cặp mà không có sóng, flash lại by mx-box nhưng not okMXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0814731
Using device: USB ROM and HTI, FW ver: 00.50, SN: 000039EC
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.73
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
Processing MCU file: rm443__09.10.mcusw
[BB5,BB5 ALGORITHM] size: 24.61 MB
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C05EF61
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1BA0010EBEA68D56BF81FB8A97B6C0CA0DA322EB
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x68680 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x76C80 bytes
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 34B3B657
Verifying communication to device OK.
Erase size: 28.25 MB
CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.657 s
CMT FLASH,NOR area [00040000-0005FFFF] erased in 0.578 s
CMT FLASH,NOR area [00060000-0007FFFF] erased in 0.703 s
CMT FLASH,NOR area [00080000-0015FFFF] erased in 4.235 s
CMT FLASH,NOR area [00160000-0023FFFF] erased in 4.703 s
CMT FLASH,NOR area [01740000-0191FFFF] erased in 9.422 s
CMT FLASH,NOR area [00240000-0173FFFF] erased in 1 min 44.422 s
CMT FLASH,NOR area [022E0000-0261FFFF] erased in 16.312 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: E8E6E2AB [RAP Certificate 140 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT ISA+DYNSW block sent
Programming completed in 2 min 28.437 s
Processing PPM file: rm443__09.10.ppm_v
[BB5,BB5 ALGORITHM] size: 7.22 MB
Erase size: 9.75 MB
CMT FLASH,NOR area [01920000-022DFFFF] erased in 48.688 s
Programming completed in 46.562 s
Processing CNT file: rm443__09.10.image_v_steel
[BB5,BB5 ALGORITHM] page size: 128 K size: 16.02 MB
Erase size: 25.62 MB
CMT FLASH,NOR area [02620000-029BFFFF] erased in 24.094 s
CMT FLASH,NOR area [029C0000-03FBFFFF] erased in 2 min 10.469 s
Programming completed in 1 min 37.719 s
Total time for flashing process(boot+erase+write) was 12 min 17.578 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Device connected: nmwcdc\Nokia 6303 classic USB Phonet, PORT_ID: 35B607CD
Phone type: RM-443 (Nokia 6303 classic)
SW version: V 09.10 25-08-09 RM-443 (c) Nokia
Imei plain: 35150504398412-2
Product code: 0584688
Battery voltage: 3698 mV, current: 191 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351505043984122
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
Market items is empty, please select the correct products path !
ae xem và hỗ tợ với thanks.
