Em mới mua box Atf chạy ngon nhưng khi flash 2700c thì mất bộ sưu tập vì ATF nó cứ convert file cnt sang 64k, em đã làm nhiều cách kể cả flash riêng file 128k cũng không được.Mong các bác giúp em với, làm cách nào để ATF tự convert file cnt sang 128k để có bộ sưu tập ạ, em cảm ơn nhiều lắm
Đây la log ạ :
ATF Software Version v8.50
ATF Box FBUS Flash Started...
Number of Image Files: 1
Basic Phone Information
MCU Version: V 09.97 18-06-10 RM-561 (c) Nokia
IMEI Plain : 352019044454704
IMEI Spare : A352019044454700
IMEI SV : 33520190444547054F
Phone Model: Nokia 2700 classic
Category : Classic Phone
Phone Type : RM-561
PM 120 Found...
PM 308 Found...
Simlock Data Saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\352019044454704\SL2_certifica te_V 09.97 18-06-10 RM-561 (c) Nokia_352019044454704_Not Locked_112633.pm
Changing MODE : FLASH
Booting Phone via FBUS...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 1B000203
ID DWORD 1 : 96D98E56
ID DWORD 2 : 3329B775
ID DWORD 3 : 58D8A880
ID DWORD 4 : 73E4C9DE
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 54
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
Secondary Loader Sent...
MessageID : 03
SubBlocks : 03
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0001 ->
Device ID : 003F -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 8A21
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Checksum : B5
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0001 DevID :003F ExtID :0000 RevID :8A21
Flash Descriptor
Device ID : 003F
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
Pabub KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
3EA22A1DDA660002E56108DB5072A10F8709443F
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
PARTNERC : Empty
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\352019044454704\3520190444547 04_112654.rpl
FlashInfo.RestartMode : 2
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.97.image_v_blac_128k
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 872
Entry Point : 0x00C8
Page Format : 128K
Maximum Page Size : 0x00004000
File Page Size is 128K...
Converting image to FAT16 64k Page Size.....
Converted file created : C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.97.image_v_blac_128k_64k
CMT Type : BB5
Page Format : 64K
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 54
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A21
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : B5
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 003F
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
No RESTORE CERTIFICATE FOUND IN IMAGE FILE
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x16 (22)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x13 (19)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 01DC0000-0215FFFF
1 : 02160000-03FBFFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:39
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing : rm561__09.97.image_v_blac_128k_64k
Total blocks to write : 872
FBUS Cable RX2 PIN Diagnostics
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:01:16
Total Flash Write Time (Flashing Only) : 00:01:16
Total Flashing Time (Booting + Erase + Flashing) : 00:02:57
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
