ATF flash x2-01 USB báo lỗi nhờ anh em giúp em vừa mua box con này là con đầu tiên,anh xem hộ là do máy hay box,thanks ae trước
Number of Image Files: 4
(Mass Memory File Detected)
Processing Image File :
rm709__08.70.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 504
Entry Point: 0x01F2
Page Format : -1
MAX PAGE : 0x0000E000
CMT Type : BB5
Entry Point: 0x01F2
Page Format : -1
rm709__08.70.ppm_t
CMT Type : BB5
Number of Blocks : 125
Entry Point: 0x0113
Page Format : -1
rm709__08.70_003.image_t_ctv_ph_9g4b0
CMT Type : BB5
Number of Blocks : 531
Entry Point: 0x0147
Page Format : -1
rm709__08.70_sd_empty.fpsimage
CMT Type : BB5
Secondary Sending Speed : 3250000Hz
Program Sending Speed : 13000000Hz
Number of Blocks : 3
Entry Point: 0x0119
Page Format : -1
MAX PAGE : 0x00020000
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
BootRom Verified!
Number of Sub Blocks 6 (0x06)
1 SYSTEM_ASIC_ID 01
Block Length : 17 (11)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000000
ID DWORD 1 : 00000000
ID DWORD 2 : 22000509
ID DWORD 3 : 200C0000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00005361
3 PUBLIC_ID 12
Block Length : 21 (15)
ID DWORD 1 : 008E1638
ID DWORD 2 : 82C15068
ID DWORD 3 : 7062FD0A
ID DWORD 4 : F3FB2C04
4 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
5 ROOT_KEY_HASH 14
Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
6 ROM_ID 15
Block Length : 9 (09)
CRC 0 : DE56D582
CRC 1 : BDDE7A3A
START FLASHING
RawLoaderExtract: rm709__08.70.mcusw
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_u sb2nd.fg
Secondary Loader Sent....
ERROR: MCU_CONFIGURATION_RESPONSE is not VALID
TIPS:
1. Make Sure your Battery Power is Enough...
2. Make Sure Connectivity Drivers are installed...
3. DO NOT USE USB HUBS...
4. Use an ORIGINAL NOKIA CA-101D USB Cable...
Flashing Failed....
Booting/Flashing Failed...
Please Try Again...
