Tình hình là máy mở nguồn lên vẩn bình thường nhưng rùi bấm ko ăn mian còn đẹp nên em bõ vào ATF chạy lại nhưng bây giờ die luôn các bác xem hộ em cai log nhé coi nó bị gì
ATF Software Version v8.10
ATF Lightning FBUS Flash Started...
Number of Image Files: 3
Forcing Test Mode via BUSCHECK...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 20C0010F
ID DWORD 1 : 56218D56
ID DWORD 2 : 5203EF04
ID DWORD 3 : 4B7CA049
ID DWORD 4 : 6517684A
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 35
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
Secondary Loader Sent...
MessageID : 03
SubBlocks : 03
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0089 ->
Device ID : 8982 -> NU48F512
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Checksum : 51
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 8982
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
Pabub KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
3EA22A1DDA660002E56108DB5072A10F8709443F
Scanning Simlock Applet Type...
OK
PA_SL3 Applet detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FlashInfo.RestartMode : 2
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
WARNING: Simlock Backup Failed
If this is a Dead Phone, just click YES
to Continue with the Flash Procedure...
Changing MODE : FLASH
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 35
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
PARTNERC : Empty
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\359360039959627\3593600399596 27_14214.rpl
Processing Image File :
C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-561\rm561__09.97.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 1256
Entry Point : 0x5047
Page Format : 128K
Maximum Page Size : 0x00004000
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 35
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:51
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing : rm561__09.97.mcusw
Total blocks to write : 1256
FBUS Cable RX2 PIN Diagnostics
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5
Block Length : 0F
BB ASIC Index : 00
Error Type : 05
Error Spec : 08
Offending Address : 0148C400
Expected Content : 0000CCB6
Detected Content : 0000CC16
Reconnect your Cable Properly because RX2 PIN
is NOT getting any DATA from the Box!!!
Flashing FAILED
BB5_WRITE_FlashFile_0
Go to Settings -->
Nokia Settings -->
FBUS DDR&2TX Synchronization Timeout
Change the current value selected to a higher value
and Restart AdvanceBox.exe software to apply it
Operations Failed....
