    Thành viên mới voquangnga's Avatar
    Dec 2010
    Mặc định e52 PHONE START-UP FAILED. CONTACT THE RETAILER CẦN GIÚP ĐỠ
    Erase size: 20.25 MB
    CMT FLASH,MuxOneNAND area [09D00000-0B13FFFF]
    Flash programming ...
    CMT SOS+ROFS3 block sent
    Programming completed in 1.891 s
    Processing CNT file: RM469_APE_ONLY_ENO_09wk23v0.091.fpsx
    [BB5,XSR 1.6] size: 2.54 MB
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
    Erase size: 4 MB
    CMT FLASH,MuxOneNAND area [004E0000-008DFFFF]
    CMT SOS*ENO block sent
    Programming completed in 0.578 s
    Processing CNT file: rm469_081.003_U006.000_prd.uda.fpsx
    [BB5,XSR 1.6] size: 12.07 MB
    Erase size: 65.25 MB
    CMT FLASH,MuxOneNAND area [0B140000-0F27FFFF]
    Programming completed in 2.282 s
    Total time for flashing process(boot+erase+write) was 41.890 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdc\Nokia E52 USB Phonet, PORT_ID: 18A011A
    Verifying communication to device OK.
    Phone type: RM-469 (Nokia E52-1)
    SW version: V ICPR82_11w16.3.5 19-08-11 RM-469 (c) Nokia
    Imei plain: 35932703620690-6
    Product code: 0591713
    Battery voltage: 3737 mV, current: 134 mA
    ApeCoreSw: 081.003
    Language Pack:
    - not available.
    SIMLOCK invalid!
    SUPERDONGLE_KEY invalid!
    - WD timer enabled, phone will reboot itself after 3 min.
    SIMLOCK_TEST failed!
    SECURITY_TEST passed
    SIMLOCK_DATA corrupted!
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.735 s
    Dec 2010
    minh chạy 3 4 lan van ko dc,mình ko biết sữa lỗi..các bạn biết chỉ dùm
    Moderator TÚ CÒI's Avatar
    hà nội
    SIMLOCK invalid!
    Tin buồn cho bạn
    Nếu backup pm full thì nạp lại đi
    Dec 2010
    bạn rỏ hơn đc ko,cảm ơn bạn nhiều.
    hà nội
    máy bạn bị bank simlock
    Nếu nhận máy bị vậy thì chịu rôi
    Nếu từ đầu ko sao mà do chạy pm bị thì bạn coi có backup được file pm thì nạp lại
    ko thì chịu rồi
    Dec 2010
    vâng,cảm bạn nhiều..
  1. phone start up failed contact the retailer
    By hamhocmobile in forum BB5
    Trả lời: 26
    Bài viết cuối: 18-04-2013, 18:07
  2. Trả lời: 12
    Bài viết cuối: 11-11-2012, 17:51
  3. N70 Phone Start-up Failed ! Contact the retailer
    By tridai_mobile in forum BB5
    Bài viết cuối: 25-02-2011, 08:27
  4. Trả lời: 9
    Bài viết cuối: 05-06-2009, 09:37
  5. Trả lời: 10
    Bài viết cuối: 18-11-2007, 20:01
