Kết quả 1 tới 10 của 12
    Thành viên mới chaychuand's Avatar
    Mar 2012
    Mặc định 3110c Cần giúp.......
    Em nhận 1con 3110c k lên nguồn.em đã flas rồi nhưng k có tiến triển gì và đây là log của nó mn xem và giúp e với...xin thanks
    Version from phone: 07.30
    Version from file: OK.mc
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C084B301
    Using device: HTI, FW ver: 00.50, SN: 000160CE
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35203202384589_BA CK.rpl).
    Processing MCU file: 3110c_TV_OK.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 13B0001632966D5635438A58D84FCAE49E1FAE83
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00020000-0007FFFF]
    CMT FLASH,NOR area [00080000-000DFFFF]
    CMT FLASH,NOR area [00100000-001FFFFF]
    CMT FLASH,NOR area [00200000-0031FFFF]
    CMT FLASH,NOR area [00320000-0105FFFF]
    CMT FLASH,NOR area [01060000-01067FFF]
    CMT FLASH,NOR area [01068000-0107FFFF]
    erased in 53.204 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    NOR: OK
    Programming completed in 57.407 s
    Processing PPM file: 3110c_TV_OK.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 4.62 MB
    CMT FLASH,NOR area [01080000-0151FFFF]
    erased in 16.484 s
    NOR: OK
    NOR: OK
    Programming completed in 18.031 s
    Processing CNT file: 3110c_TV_OK.image_ora_pl_games_128
    [BB5,BB5 ALGORITHM] page size: 64 K size: 4.63 MB
    NOR page size in the phone is 128 K.
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 10.75 MB
    CMT FLASH,NOR area [01520000-01FDFFFF]
    erased in 35.187 s
    NOR: OK
    UCP page size is 128 K.
    NOR: OK
    Programming completed in 19.781 s
    Total time for flashing process(boot+erase+write) was 3 min 53.844 s
    Phone type: RM-237 (Nokia 3110c)
    SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
    Imei plain: 35203202384589-1
    Product code: 0552816
    Battery voltage: 4625 mV, current: 84 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 352032023845891
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    tình trạng ban đầu sao vậy bạn có rơi rớt gì không
    chủ tài khoản: TRẦN VĂN SƠN
    TK MB : 9990 1113 95201
    VCB :0021.000.296.541
    yahoo : TVS_88
    Thành viên tích cực ko.ko80's Avatar
    Jul 2011
    coi lại đường bí coi bạn
    V.I.P ThanhTuMobile's Avatar
    Sông Vàm Cỏ Đông LộcGiang-ĐứcHoà-Long An
    có HWK hay ATF thì Flash lai cho nó cái nữa xem sao/
    KHÔNG THAY ĐỔI THÌ CHẤP NHẬN CHẤP NHẬN THÌ KHÔNG THAY ĐỔI
    VẠN NGƯỜI QUEN CÓ MẤY NGƯỜI THÂN KHI LÌA TRẦN CÓ MẤY NGƯỜI ĐƯA
    May 2011
    Hà Nội City
    Log quá đẹp rùi
    bạn kẹp nguồn xem kim dao động thế nào nhé
    Apr 2010
    log này quá ok rồi xem lại chân pin và công tắt nguồn đi anh ơi..máy lúc trước như thế nào anh
    Thành viên tích cực thuy1986's Avatar
    chắc đứt công tắc nguồn ? hàn lại không được thay cái khác
    Mar 2012
    kẹp cái là kim nó nhíc lên 1tẹo luôn và treo
    thay thử dao động cái tính tiếp
    Trích Được post bởi ThanhTuMobile Xem bài viết
    vip ơi theo vip thì thay con dao động thì có tác dụng gì ? theo vip nếu máy không có dao động thì có check và flash được không ( trong khi đó log quá mượt ) ? vip chi em hiểu thêm với ?
  1. 3110c cần ae giúp
    By hoang_an in forum BB5
    Bài viết cuối: 31-12-2011, 10:39
  2. 3110c nhơ ae giúp gấp
    By rap_3g in forum BB5
    Bài viết cuối: 12-09-2010, 23:13
  3. 3110c cần giúp dỡ
    By khanhhung99 in forum BB5
    Bài viết cuối: 13-10-2009, 13:15
  4. 3110c cần giúp
    By donghuythoai in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 14-06-2009, 00:13
  5. 3110c màn hình chớp tắt cần giúp
    By vovanha2007105 in forum BB5
    Bài viết cuối: 10-06-2009, 09:42
