Tình hình là sau khi up FW cho con Nokia N96 RM-247 bằng phoenix thì em nó bị trắng màn hình, log của phoenix đây ạ:
Sau đó em có thử up bằng JAF nhưng tình hình vẫn không khả quan hơn là mấy, log JAF đây ạ:Code:Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 39104 bytes Secondary boot loaded BB Asic Index is: 01 Asic ID is: 008815D3 BB Asic Index is: 01 EM Asic ID is: 000001B2 BB Asic Index is: 01 EM Asic ID is: 000001B3 BB Asic Index is: 01 Public ID is: 01381A9EE0FDDCBE887494496B7DBD72B67CE60A BB Asic Index is: 01 Asic Mode ID: 00 BB Asic Index is: 01 Hash: 0BBC4203E2D3B82504C75CB65E906A35 BB Asic Index is: 01 ROM ID: 137A9A3B33259D2C BB Asic Index is: 01 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 01 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 01 Device type is: 03 Device Index is: 00 Manufacturer code: 0020 Device ID: 00B1 Extended device ID: 0000 Revision ID: 0000 Loading update server code: 377373 bytes Update server loaded Loading slave secondary boot code: 15232 bytes Slave secondary boot code loaded BB Asic Index is: 00 Asic ID is: 000000010000022600010006400C192101031103 BB Asic Index is: 00 EM Asic ID is: 00000295 BB Asic Index is: 00 EM Asic ID is: 00000B22 BB Asic Index is: 00 Public ID is: 1E900007DD6B0052D33886496EA573BBAD9D60EE BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: CAEEBB65D3C48E6DC73B49DC5063A2EE BB Asic Index is: 00 ROM ID: 4B9B75103E691FF8 BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0001 Device ID: 2C7E Extended device ID: 0000 Revision ID: 6921 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 Loading slave update server code: 555471 bytes Slave update server loaded Asic CMT: Start programming 5968 KB... Asic CMT: Programming data sent: 0% Asic CMT: Programming data sent: 10% Asic CMT: Programming data sent: 20% Asic CMT: Programming data sent: 30% Asic CMT: Programming data sent: 40% Asic CMT: Programming data sent: 50% Asic CMT: Programming data sent: 60% Asic CMT: Programming data sent: 70% Asic CMT: Programming data sent: 80% Asic CMT: Programming data sent: 90% Asic CMT: Programming data sent: 100% Asic APE: Start programming 114905 KB... Asic APE: Programming data sent: 0% Asic APE: Programming data sent: 10% Asic APE: Programming data sent: 20% Asic APE: Programming data sent: 30% Asic APE: Programming data sent: 40% Asic APE: Programming data sent: 50% Asic APE: Programming data sent: 60% Asic APE: Programming data sent: 70% Asic APE: Programming data sent: 80% Asic APE: Programming data sent: 90% Asic APE: Programming data sent: 100% Programming complete Asic CMT: Verifying communication to device... Waiting for communication response: 25 Waiting for communication response: 24 Waiting for communication response: 23 Waiting for communication response: 22 Waiting for communication response: 21 Waiting for communication response: 20 Waiting for communication response: 19 Waiting for communication response: 18 Waiting for communication response: 17 Waiting for communication response: 16 Waiting for communication response: 15 Waiting for communication response: 14 Waiting for communication response: 13 Waiting for communication response: 12 Waiting for communication response: 11 Waiting for communication response: 10 Waiting for communication response: 9 Waiting for communication response: 8 Waiting for communication response: 7 Waiting for communication response: 6 Waiting for communication response: 5 Waiting for communication response: 4 Waiting for communication response: 3 Waiting for communication response: 2 Waiting for communication response: 1 Error 0x8401F121 communicating to phone. Unable to verify comm. Starting to recover the phone Recovering phone Initializing Warning: Unable to communicate to product after flashing Scanning image files... ERROR: Unable to detect device 0x8401F145. Check USB connection ERROR: Product recovery failed Unable to set the phone to flash mode. Unable to flash. Starting to recover the phone Recovering phone Initializing Scanning image files... Unable to set the phone to flash mode. Unable to flash. All operations completed Product flashing aborted
Giờ đang đau đầu với em nó quá, mong anh em ai có kinh nghiệm thì giúp đỡ đàn em, cám ơn ạ.Code:JAF version 1.98.62 Detected PKEY: 900098CD Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.1.45.0 Changing mode...Done! Detected P-KEY: 900098CD P-key nokia module version 01.02 Init usb communication... Failed! Aborting! Detected P-KEY: 900098CD P-key nokia module version 01.02 Init usb communication... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-247\ Searching for default location of ini... Checking path: \Products\RM-247\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-247\ Scanning ini files... Searching for default location of ini... Checking path: \Products\RM-247\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_prd.core.fpsx PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_019.1_prd.language.fpsx CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_098.1_prd.customer.fpsx APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_100.1_prd.uda.fpsx Languages in ppm: English,Philipines,Indonesia,India,Vietnam,New Zealand Detected P-KEY: 900098CD P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending APE boot... Loader version: 00.00.00 -> Revision: 0200 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... Sending ape boot... APE FLASHID: B1002000 Sending APE loader... Waiting for Update Server to boot... Sending CMT boot... Loader version: 08.24.00 -> Revision: 0200 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT FLASHID: 7E2C0100 Sending CMT loader... Reading CMT papub hash... Reading APE papub hash... CMT blocks: 414, APE blocks: 3615 Partition CMT... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_prd.core.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_019.1_prd.language.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_098.1_prd.customer.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_100.1_prd.uda.fpsx... Partition APE... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_prd.core.fpsx... Sending APE partition Data... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_019.1_prd.language.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_098.1_prd.customer.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_100.1_prd.uda.fpsx... Erase CMT... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_prd.core.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_019.1_prd.language.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_098.1_prd.customer.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_100.1_prd.uda.fpsx... Erase APE... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_prd.core.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_019.1_prd.language.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_098.1_prd.customer.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_100.1_prd.uda.fpsx... Write CMT... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_prd.core.fpsx... Sending CMT HASH for NOLO Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC MATCH cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... PAPUBKEYS already sent... PAPUBKEYS already sent... PAPUBKEYS already sent... PAPUBKEYS already sent... Sending CMT HASH for UPDAPP Sending CMT HASH for DSP0 Sending CMT HASH for MCUSW Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_019.1_prd.language.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_098.1_prd.customer.fpsx... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_100.1_prd.uda.fpsx... Write APE... Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_prd.core.fpsx... Sending APE HASH for X-LOADER Sending APE HASH for KEYS Sending APE HASH for PRIMAAPP Sending APE HASH for SOS*UPDAPP Sending APE HASH for SOS+XZIP Sending APE HASH for PASUBTOC MATCH ape->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... Sending APE HASH for SOS+CORE Sending APE HASH for SOS+ROFS1 Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_019.1_prd.language.fpsx... Sending APE HASH for SOS+ROFS2 Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_098.1_prd.customer.fpsx... Sending APE HASH for SOS+ROFS3 Processing C:\Program Files\Nokia\Phoenix\Products\RM-247\RM-247_30.033_100.1_prd.uda.fpsx... Rebooting... Pooling phone... Phone not found... Done!
À em up bằng cáp USB với 2 tools trên ạ.
Chân thành cám ơn các anh.
			 Nokia N96 sau khi Flash FW thì bị trắng màn hình và tắt, xin giúp!!
