    Thành viên mới caonguyenbz's Avatar
    Dec 2010
    Mặc định n6233 khởi động nguồn treo nokia rồi tắt
    như tiêu đề e mới nhận một cây 6233 rớt nước ,đã hấp và sáy kĩ nhưng bật nguồn lên treo nokia rồi tắt.đã làm pm rồi mà vẫn vậy
    ae xem dùm cái log luôn :
    Version from phone: 05.60
    Version from file: 05.60
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C085E89E
    Using device: HTI, FW ver: 00.50, SN: 0001663F
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20454(13-03-2012), Library ver: 1.0.0.13962(12-03-2012)
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35628301160345_BA CK.rpl).
    Processing MCU file: rm123_145_30005.600.mcusw
    [BB5,BB5 ALGORITHM] size: 16.29 MB
    Supported Ids: 0103192101003000, 010C192101003000
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 28A00116BAA701548A6802E852B33E1DE92B48CC
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0001 002F - 0000 0121 [AMD S29NS256N,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 2F36DDC4990FD844712A61A80C033211BD9602E3
    TransmissionMode: DDR&TX2
    Erase size: 17.75 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0000FFFF]
    CMT FLASH,NOR area [00010000-0007FFFF]
    CMT FLASH,NOR area [000A0000-0021FFFF]
    CMT FLASH,NOR area [00220000-011DDFFF]
    CMT FLASH,NOR area [011DE000-011DEFFF]
    CMT FLASH,NOR area [011DF000-011DFFFF]
    erased in 1 min 22.500 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 2F36DDC4 [Rap certificate 24 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    NOR: OK
    Programming completed in 1 min 17.609 s
    Processing PPM file: rm123_145_3005.60.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.84 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 5 MB
    CMT FLASH,NOR area [011E0000-016DFFFF]
    erased in 23.453 s
    NOR: OK
    NOR: OK
    Programming completed in 22.672 s
    Processing CNT file: rm123_145_30005.60.image_v
    [BB5,BB5 ALGORITHM] page size: 64 K size: 3.25 MB
    NOR page size in the phone is 128 K.
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 9 MB
    CMT FLASH,NOR area [016E0000-01E7FFFF]
    CMT FLASH,NOR area [01E80000-01FDFFFF]
    erased in 43.469 s
    NOR: OK
    Converting UCP blocks to 128 K.
    NOR: OK
    Programming completed in 14.829 s
    Total time for flashing process(boot+erase+write) was 5 min 5.187 s
    Phone type: RM-145 (Nokia 6233)
    SW version: V 05.60 14-09-07 RM-145 (c) Nokia
    Imei plain: 35628301160345-5
    Product code: 0536490
    Battery voltage: 4491 mV, current: 61 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY invalid!
    - WD timer enabled, phone will reboot itself after 3 min.
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 356283011603455
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    PROFILE_BITS: 8000000000000002
    FULL FACTORY... OK
    USER DATA... Failed! (0102)
    Completed in 2.172 s
    Moderator TÚ CÒI's Avatar
    hà nội
    backup rồi xóa full nạp lại xem sao
    KO được cách ly blutooth coi sao
    -->Ram
  3. ( TÚ CÒI ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    caonguyenbz (15-04-2012)
    Thành viên mới Unlock_Girl's Avatar
    Trích Được post bởi NGUYỄNTÚ_HỒNGNHUNG_GSM Xem bài viết
    -->Ram
    làm như mod này xem
    ĐIẾU THUỐC LÁ SƯỞI ẤM TRÁI TIM HỒNG
    CHÉN RƯỢU NỒNG LÀM BẠN LÚC CÔ ĐƠN
    Thành viên chính thức kpmobile™'s Avatar
    Ba Vì_Hà Nội
    Coi cái log thấy bank SD.
    Giải quyết : Repair SD+sx4+write pm 1&309.Xong flash lại cho chắc
    Chưa hết bệnh treo nokia thì tính tiếp
  6. ( kpmobile™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Thành viên chính thức toanmobilels's Avatar
    Mar 2011
    bạn đóng lại fash xem có được không,bệnh này mình đã tưng gặp trên n6300 rồi đóng lại fash don luân.
  8. ( toanmobilels ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Moderator VanTuan-ST's Avatar
    Sóc Trăng
    Banh vùng sd rồi, Repaire SD, SX4 ,Wr pm 1 & 309 update simlock.
  10. ( VanTuan-ST ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #7
    Dec 2010
    ok để e làm thử có gì báo lại sau tk
  12. #8
    Dec 2010
    đã làm như bác vantuan-st và cũng đã đóng flash lun rồi nhưng chỉ thấy vào được khởi động không cần thẻ sim cũng treo một lúc rồi tắt. giờ phải làm j nữa nhờ các bác chi giúp !
  13. #9
    Thành viên chính thức THANHTUYEN0984813138's Avatar
    khả năng bi lổi căp luôn roi làm chân căp dong lai xem ntn
Hiện có 3 người đang xem bài này . Bao gồm : 0 thành viên và 3 khách
  1. Trả lời: 2
    Bài viết cuối: 09-05-2013, 19:56
  2. Trả lời: 6
    Bài viết cuối: 19-01-2013, 17:28
  3. Help Me! N6233 mất nguôn!
    By ducmt49 in forum BB5
    Bài viết cuối: 10-07-2010, 16:44
  4. Trả lời: 10
    Bài viết cuối: 06-03-2009, 22:19
