Version from phone: 51.1.002
Version from file: 51.1.002
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C086DB00
Using device: HTI, FW ver: 00.50, SN: 01002398
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35200004160114_BA CK.rpl).
Processing MCU file: RM-625_51.1.002_prd.core.C00
[BB5,XSR 1.6] size: 95.97 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 09500116E690005242E4453121570FE1FC3CBDBC
ASIC MODE ID: 00
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.50.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 11.50.0 revision: 2.0 size: 0x93383
CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 3 min 10.109 s
Processing PPM file: RM-625_51.1.002_prd.rofs2.V16
[BB5,XSR 1.6] size: 20.77 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 36.50 MB
CMT FLASH,MuxOneNAND area [06CE0000-0915FFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 42.390 s
Processing CNT file: RM625_51.1.002_000_001_U001.uda.fpsx
[BB5,XSR 1.6] size: 17.07 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 86.12 MB
CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF]
NAND: OK
NAND: OK
Programming completed in 35.750 s
Total time for flashing process(boot+erase+write) was 4 min 56.985 s
Phone type: RM-625 (Nokia 5233)
SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia
ApeCoreSw: V 51.1.002
Imei plain: 35200004160114-1
Product code: 059C7S1
Battery voltage: 4704 mV, current: 188 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.609 s
chắc phải thây cặp hả các bác, máy lúc đầu mang đến trong tình trạng banh chành imei e tìm trong pc có rpl vì máy này e đã chạy qua rồi bằng mxbox nên có rpl và đã write rpl chắc mình rpl cũng ko gải quyêt đc sl3 đúng ko. cho ý kiến nhé các bác.
			 anh e xem hộ cái log 5233
