các anh ơi giú
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00009785
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.70
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
Processing MCU file: rm578__10.45.mcusw
[BB5,BB5 ALGORITHM] size: 21.65 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 14B948AE
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101023000
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 0210010A9D1B0456A26E2E725931895AF1F9C198
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2C2C9F9B
Verifying communication to device OK.
Erase size: 23.25 MB
CMT FLASH,NOR area [00000000-000006BF] erased in 0.610 s
CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.609 s
CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.484 s
CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.532 s
CMT FLASH,NOR area [00140000-0155FFFF] erased in 1 min 38.156 s
CMT FLASH,NOR area [01560000-0175FFFF] erased in 9.922 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 8669C775 [RAP Certificate 215 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 1 min 19.469 s
Processing PPM file: rm578__10.45.ppm_v
[BB5,BB5 ALGORITHM] size: 6.78 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01760000-01FFFFFF] erased in 41.500 s
Programming completed in 24.750 s
Processing CNT file: rm578__10.45.image_v_black_v2
[BB5,BB5 ALGORITHM] page size: 128 K size: 15.64 MB
Erase size: 31.75 MB
CMT FLASH,NOR area [02000000-0245FFFF] erased in 27.469 s
CMT FLASH,NOR area [02460000-03FBFFFF] erased in 2 min 59.063 s
Converting UCP blocks to 128 K.
Programming completed in 56.968 s
Total time for flashing process(boot+erase+write) was 9 min 21.703 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Device connected: nmwcdc\Nokia 2730 classic USB Phonet, PORT_ID: 1B7CA771
Phone type: RM-578 (Nokia 2730 classic)
SW version: V 10.45 05-07-10 RM-578 (c) Nokia
Imei plain: 35593104762748-1
Product code: 059C0H6
Battery voltage: 3751 mV, current: 68 mA
Language Pack:
- not available.
Camera config: NI00IIIIRR030102F201, ver: 006.006
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 355931047627481
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.688 s
p e con 2730 contac e chạy lại nhưng vẫn k dược
