mình nhận cây 5310 khởi động len nokia rồi tắt treo 1.8 , mình đã nạp pm rồi vẫn ko hết , dưới đây là log của e nó , ae xem giúp mình với.......
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C084160D
Using device: HTI, FW ver: 00.50, SN: 00010AAF
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101013000
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1C00010681135950E05FB134EC830BBE64B3C80E
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
eBB5ProtocolType: OLD
Storage0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D
TransmissionMode: DDR&TX2
Processing MCU file: rm303__09.42.mcusw
[BB5,BB5 ALGORITHM] size: 17.07 MB
Erase size: 18 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-010DFFFF]
CMT FLASH,NOR area [010E0000-0121FFFF]
erased in 1 min 6.656 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 3E96DE42 [RAP Certificate 90 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 15.922 s
Processing PPM file: rm303__09.42.ppm_v
[BB5,BB5 ALGORITHM] size: 6.24 MB
Erase size: 6.50 MB
CMT FLASH,NOR area [01220000-0189FFFF]
erased in 24.125 s
NOR: OK
NOR: OK
Programming completed in 29.047 s
Processing CNT file: rm303__09.42.image_v_red
[BB5,BB5 ALGORITHM] page size: 128 K size: 10.01 MB
Erase size: 39.12 MB
CMT FLASH,NOR area [018A0000-01B1FFFF]
CMT FLASH,NOR area [01B20000-03FBFFFF]
erased in 2 min 54.406 s
NOR: OK
NOR: OK
Programming completed in 46.578 s
Total time for flashing process(boot+erase+write) was 7 min 4.157 s
Phone type: RM-303 (Nokia 5310 XpressMusic)
SW version: V 09.42 07-11-08 RM-303 (c) Nokia
Imei plain: 35687002839009-0
Product code: 0565758
Battery voltage: 4525 mV, current: 15 mA
Language Pack:
- not available.
SLPA ver[2]: PA_SL2 (15 digit NCK)
Camera config: XXXXXX, ver:
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356870028390090
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
			 5310 cần ae giúp
 5310 cần ae giúp
