Kết quả 1 tới 10 của 14
    Thành viên chính thức vungtaumobifone's Avatar
    Mặc định 2700c máy báo sẵn sàng và nghe nhạc 1 lúc tắt nguồn
    như tiêu đề đây là log.nhờ ae hướng dẩn dùm
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085C6B5
    Driver: nmwcdc, ver: 7.1.32.67
    Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35826203785050_PM .rpl).
    Processing MCU file: rm561__09.98.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    NOR page size in the phone is 128 K.
    Battery voltage: 3856 mV
    Phone type: RM-561 (Nokia 2700 Classic)
    Product code: 0588540
    SW version: V 09.98 - 06-09-10 - RM-561 - (c) Nokia
    LanguagePkg version: 7 - 18-06-10 - RM-561 - (c) Nokia - V
    Version from phone: 09.98
    Version from file: 09.98
    CMT BOOT ID: 0803000302010000
    CMT PUBLIC ID: 12900214C1978C566A048A89F44CE5EA2CCFAE38
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    Storage0: 0089 8982 - 0000 FFFF [Intel NU48F512,512 Mbits] type: NOR, asic:CMT
    Storage0: 0000 0000 - 0000 0000 [unused/removed] type: NAND, asic:APE
    Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
    Update Server code succesfully sent to phone.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 3B791826
    Verifying communication to device OK.
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.000 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.000 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 0.156 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 0.171 s
    CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 58.828 s
    CMT FLASH,NOR area [01380000-0151FFFF] erased in 10.533 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 9.587 s
    Processing PPM file: rm561__09.98.ppm_t
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF] erased in 56.101 s
    Programming completed in 25.112 s
    Processing CNT file: rm561__09.98.image_ctv_nz_gray_128
    [BB5,BB5 ALGORITHM] page size: 128 K size: 10.95 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 27.394 s
    CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 49.858 s
    UCP page size is 128 K.
    Programming completed in 38.099 s
    Total time for flashing process(boot+erase+write) was 9 min 48.638 s
    Device connected: nmwcdc\Nokia 2700 classic USB Phonet, PORT_ID: 18B2E338
    Phone type: RM-561 (Nokia 2700 classic)
    SW version: V 09.98 06-09-10 RM-561 (c) Nokia
    Imei plain: 35826203785050-4
    Battery voltage: 3828 mV, current: 75 mA
    Language Pack:
    - not available.
    Detected as PA_SL3 phone.
    - Avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 358262037850504
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Nokia 2700 classic USB Phonet detached.
    BỆNH CUẢ MÁY NHƯ VÙNG SA MẠC!!!!
    KIẾN THỨC TA CHỈ LÀ HẠT CÁT...??????
    Thành viên chính thức canhlamdl's Avatar
    haz``` bệnh này muôn thưở
    Chú ý bài viết nhé
    Thành viên chính thức toantkx92's Avatar
    Jun 2011
    sua loi 1 vả 309 xem
    chay pm wire pm luôn Sd luôn đi bạn
    Apr 2010
    này anh lấy hwk hoặc phoenix flash cái đi anh ơi nhớ simlock em nó cái nha anh
    Thành viên tích cực daochikien's Avatar
    Mar 2012
    hai duong
    anh mang qua box khác chạy lại xem có được không
    Quân đến thì tướng đánh _ Nước mạnh thì đắp đê...!
    Moderator TÚ CÒI's Avatar
    hà nội
    Chuẩn bị phương án thay flat là vừa(khắc phục lỗi tắt nguồn)
    Camera thì cho fix lại coi sao đã
    chạy lại ok nhu vậy ko tắt nguồn khi nghe nhạc nũa nhung còn camera do áp vẫn thông nhung cung ko chup dc
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    nếu log như trên mà vẫn nghe nhạc 1 lúc là tắt thì back up full rồi thay flash đi bạn .
    còn nếu đã ok rùi thì còn cái camera thì fix lại cho nó cái . đây là file fix . chúc vui
    2700c_NIMMIIIIRRFF06150018_002.008.pm
    2700c_NIMMIIIIRRFF0A021001_002.007.pm
    2700c_NIMMIIIIRRFF094B2F01_002.014.pm
    yahoo: viethuy_mobi
    Thành viên tích cực khangdl84's Avatar
    Nov 2011
    camera bị máy ảnh sảng sàn hạ bạn. bạn nân tiếp xúc cam lên nhé. đè ép chặc cam xuống thử chụp được không nhé. máy cái cam dòng này khi tháo ra bỏ vào hay bị bệnh này lắm
  11. ( khangdl84 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    dauphaiem (24-04-2012)
  1. 2700c lúc bật nguồn lên, lúc không !
    By PhùngMobile in forum BB5
    Bài viết cuối: 03-02-2012, 15:22
  2. 3110c nghe nhạc một lúc tắt nguồn
    By mitifones in forum BB5
    Bài viết cuối: 15-06-2010, 13:41
  3. Trả lời: 2
    Bài viết cuối: 05-12-2008, 16:49
  4. n91 nghe nhạc một lúc mất nguồn
    By binh_gsm in forum BB5
    Bài viết cuối: 24-11-2008, 20:30
  5. Trả lời: 6
    Bài viết cuối: 21-10-2008, 18:20
