    Thành viên chính thức THANHTUYEN0984813138's Avatar
    Mặc định ae xem dùm mình cái log 6100
    tình hình e nó bi tím màn dả câu kéo như trên mang mình da search nhưng vẩn not ok thay màn rin dang xài vẩn not ok ae xem dùm cái log rồi cho mình ý kiến ah
    MCU SW : V 05.16 26-09-03 NPL-2 (c) NMP.
    PPM SW : V 05.16 26-09-03 NPL-2 (c) NMP V
    Prd.Code: 0510845
    Bpr.Code: 0511917
    Prod.Sn : DCE311516
    HW Vers : 2965
    PCI Vers: 0
    UEM : 48
    UPP : 4384 [1120]
    RFIC Ver: 0300
    DSP Vers: 7.90-4.60
    LCD Type: SED15G10
    IMEI : 351535-00-950000-0
    SL Conf : 001-01-00000000000
    SL Prof : 000000000000000-2
    SL Var : 00553515350095000000
    SL Aux : 00020000
    Box Id : 8F3DFFFFFFFFFFFF
    BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    MastCode: 45 11 36 34 07
    Provider: GSM Test Equipment
    #pw+ 299 945 610 701 051 +1#
    #pw+ 923 362 145 175 277 +2#
    #pw+ 882 491 104 066 103 +3#
    #pw+ 044 003 562 252 215 +4#
    #pw+ 048 843 661 620 054 +5#
    #pw+ 825 921 240 321 232 +6#
    #pw+ 206 565 024 427 375 +7#
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    log thì ok rồi .tím màn nhưng nếu nghe gọi ok thì cứ chổ suket mà làm ..kiểm tra lại tất cả các đường coi có thiếu gì không + 2 áp cấp cho nó nữa
    1st Boot: Ok, DCT4, UPP: 1120 [Npl-2] [2.2.0.0]
    2nd Boot: u_2nd.fia, Ver: 4.79.0
    FlId Aliasing with: 00EC22F0
    Fl0: 0x01000000-0x017FFFFF,00EC22F2,Sam K5U64418TM
    Algorithm: u_amd.fia, Ver: 4.79.0
    Algorithm Ok, MSID: 8437C171652B69FBF032F1FC1C
    Decoded MSID: 82A9BAE9-00C318D2-A9000000
    Encoded FAID: 20CA390E-C3003250-3D887502
    IMAGE: npl2__06.200
    Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
    Area2: 0x01010000-0x0157FFFF Erased, Time: 00:50
    Area3: 0x016B0000-0x017EFFFF Erased, Time: 00:11
    Area4: 0x01EB0000-0x01FEFFFF Out of Chip Bounds
    MCU Flashing Completed, Time: 00:58
    IMAGE: npl2__06.20u
    Area1: 0x01580000-0x016AFFFF Erased, Time: 00:10
    CNT Flashing Completed, Time: 00:09
    Running: Nokia File Server
    CNT Extract Warning, Res: 0, CNT Area not Empty
    Contents Package Extracting Ok, Time: 00:07
    Algorithm Ok, MSID: 846C6CAA0962341DFFB3CA6B36
    Decoded MSID: 82A9BAE9-00C318D2-AA000000
    Encoded FAID: 3359D517-82A020C8-07F7BA81
    IMAGE: npl2__06.20v
    PPM Flashing Completed, Time: 00:11
    Flashing Completed, Rebooting Mobile
    Thành viên tích cực HOÀNGTRUY_GSM's Avatar
    Jan 2011
    Cần Thơ
    Câu chân 9,10 với nhau.not ok đá U cái(ko thì làm chân)
  6. ( HOÀNGTRUY_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    htcantho (01-05-2012)
  1. Anh em xem dùm em cái log 6100
    By KHA_MOBILE67 in forum DCT4 - WD2
    Bài viết cuối: 07-04-2012, 23:41
  2. anh em xem dùm cái log 6100
    By thenguyenkhanhhoa in forum DCT4 - WD2
    Trả lời: 23
    Bài viết cuối: 05-08-2009, 17:36
  3. cúu dùm con 6100
    By huuhoaiph in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 09-11-2008, 16:15
