ATF v8.70 Update!! Public Discussion Thread:
Flashing Updates:
--> Lumia 900 RM-808 and RM-823 Now Fully Supported and Tested
--> Blocked Cross Flashing a X3-02.5 (RM-775) with a X3-02 (RM-639) Flash File
--> Blocked Cross Flashing a C3-01.5 (RM-776) with a C3-01 (RM-640) Flash File
--> Dual CPU (CMT + APE) New Protocol FBUS Flashing Re-Activated (N95, E90)
--> Dual CPU (CMT + APE) Phone Authorize via The ATF Network Re-Activated
--> Dual CPU (CMT + APE) ADL USB Flashing Re-Activated (N95-8GB, N95, N73, E90)
--> Dual CPU (CMT + APE) First In The World ADL USB Recovery Flashing (N95-8GB, N95, E90)
Other Updates:
--> Improved Drive Detection for ALL SYMBIAN APE Phones...
--> FORMAT FILE SYSTEM Now Supports S40 FILE2 Drives (5130c, X2-01, etc..)
--> REMOVE SD Card Password via S40 Phone FILE2 Format of Drive E:
DCT4 Update:
--> DCT4 ASIC 2-5-6-7 SP Data Rebuild for DIRECT UNLOCK and REPAIR
Other Updates:
--> New Products Added to Nokia.ini
Bugs Killed in this Update:
--> Fixed SUB SCAN PHONE = PC Restart Bug on some AMD and Intel Core2 Computers
--> Fixed USB Flashing "MCU CONFIGURATION IS NOT VALID"
--> Fixed Battery Value 0 Error When Flashing via USB
--> Fixed USB Booting Problem Delay on FUR
--> Fixed FBUS Buscheck Timeout Delays (Faster Buschecks Now)
--> Fixed Bug on Unsupported "NORMALIZE SUSD" Flash Files
--> Fixed RAP3Gv3 FBUS Flashing Bug "Please Check RX2 Blah Blah..."
--> Adjusted Infineon USB Flashing to exit properly during a Flash Error
Special Thanks Goes To:
ashish_gsm <-- USB Scan Phone Surrogate PC for Debugging
MOYAL <-- USB Scan Phone Fix Beta Tester
Some Clarifications:
1. Old Phones Can now be flashed with New Loaders and New Protocol (like 5130 and N95-8GB).
But it is still BETTER to use OLD PROTOCOL and OLD LOADERS for these Phones.
2. You can now flash N95-8GB, N73, E90 etc via USB Cable Only.
3. Nitro and Lightning users can now EASILY REMOVE Password from any SD Card without buying
or making an SD Card Cable Adapter. Simply put SD Card inside a S40 Phone like 5130c or
X2-01 etc... When card is now inside the phone, use FILE SYSTEM FORMAT Option to Format
Drive E:... That is it!
Who will buy this if you can get more in ATF?
__________________________________________________ ________________________
Buy only from ATF [Advance Turbo Flasher] authorized resellers:
ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
ATF [Advance Turbo Flasher] official web sites:
International - http://www.advance-box.com/
ATF [Advance Turbo Flasher] official support forums:
World Wide: Advance Turbo Flasher - GSM-Forum
Indonesia: ATF (Advance Turbo Flasher))
Philippine: Gsmph
Syria: Arabic Support (Syria) GsmVIP
Chinese support forum : ATF Box
Vietnam: Saigonmobile
India: Advance Box - .:: GsmIndia ::.
Official Iran Support Forum : ASANGSM FORUM
Bangladesh: Advance Box - Dhaka Mobile
Chinese Support forum : www.yananliuhuan.com
The Master Piece
