MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0860692
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010025F8
Connection status: EHCI:HUB:USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.75
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 000000000092FE84C7F9385698730FB13C4A4CD5
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13F34393
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738
Selected firmware certificate matched.
Original Imei: 35165705457677
Original Product code: 059C4G1
Bluetooth ID: 94007013521F
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Device connected: nmwcdc\Nokia X2-00 USB Phonet, PORT_ID: 20C769CB
Verifying communication to device...
ERROR: Could not verify communication !
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
Em Check Nó báo thế này ....ae em dùm cái
			 ae xem dùm cáicon x2-00
