    Thành viên chính thức vungtaumobifone's Avatar
    Mặc định 7310c lên nokia treo chớp tắt
    chạy bằng cáp thì hết dòng MCU là bị đứng lai
    chạy usb nó như vậy ae coi dùm
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085C6B5
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.67
    Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
    Processing MCU file: rm379__09.40.mcusw
    [BB5,BB5 ALGORITHM] size: 17.09 MB
    Waiting for USB device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 25408D92
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    CMT EM0 ID: 00000295
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 23200201A53A7D563CBC7C6624396EFA0E99C0DB
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x48480 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x56A40 bytes
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 3B791826
    Verifying communication to device OK.
    Erase size: 18 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.343 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.016 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 1.515 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 0.219 s
    CMT FLASH,NOR area [00140000-010DFFFF] erased in 43.328 s
    CMT FLASH,NOR area [010E0000-0121FFFF] erased in 3.375 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 1C4FF759 [RAP Certificate 111 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 58.547 s
    Processing PPM file: rm379__09.40.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.34 MB
    Erase size: 6.62 MB
    CMT FLASH,NOR area [01220000-018BFFFF] erased in 17.875 s
    Programming completed in 45.563 s
    Processing CNT file: rm379__09.40.image_v
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.14 MB
    Erase size: 39 MB
    CMT FLASH,NOR area [018C0000-01B3FFFF] erased in 7.203 s
    CMT FLASH,NOR area [01B40000-03FBFFFF] erased in 42.391 s
    Programming completed in 1 min 28.407 s
    Total time for flashing process(boot+erase+write) was 6 min 28.266 s
    Phone not found, retrying ...
    Verifying communication to device...
    ERROR: Could not verify communication !
    Market items is empty, please select the correct products path !
    BỆNH CUẢ MÁY NHƯ VÙNG SA MẠC!!!!
    KIẾN THỨC TA CHỈ LÀ HẠT CÁT...??????
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    làm chân con flash rồi flash lại xem pro
  3. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    vungtaumobifone (12-05-2012)
    Thành viên tích cực sang_apple's Avatar
    Feb 2012
    F,3 Q4 ,Hồ Chí Minh
    bạn bỏ vào box khác flash thử xem sao
    Luôn lắng nghe và học hỏi....
  5. ( sang_apple ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Apr 2010
    xem lại cáp đi anh đưa vào box khác mà flash anh không hết là bị flash rồi nhé
  7. ( KHA_MOBILE67 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #5
    Thành viên chính thức toantkx92's Avatar
    Jun 2011
    đóng cặp lại đj bạn
  9. #6
    tự nhiên cho vào úb lại bút cái nó len nguồn luôn thaks anh em nhiều
  1. Trả lời: 5
    Bài viết cuối: 27-08-2013, 08:32
  2. Trả lời: 7
    Bài viết cuối: 08-08-2013, 09:10
  3. Trả lời: 2
    Bài viết cuối: 09-05-2013, 19:56
  4. 7310c bật nguồn lên ic nóng ran....help me
    By chuminhtruong55 in forum BB5
    Bài viết cuối: 13-08-2010, 15:39
  5. Trả lời: 7
    Bài viết cuối: 24-05-2010, 07:08
