    Thành viên mới bvcxz234's Avatar
    Jan 2011
    Question Nokia-6730.....Rm-566.... cần anh em giúp..
    em có con Nokia 6730.......Rm-566............ mình chạy ver cao nhất rồi mà vân không đươc...... máy mở lên rung 1 cái rồi thôi... mong anh em giúp đơ mình với......
    MXKEY [FT SCR2000 0], SN: C0801C94
    Using device: USB Phonet
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
    Processing MCU file: rm566_031.022_prd.core.fpsx
    [BB5,XSR 1.6] size: 91.24 MB
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000030000022600010007
    600C192102011104 [RAPUYAMA ver: 1.1]
    CMT EM0 ID: 00000C34
    CMT EM1 ID: 00000C30
    CMT PUBLIC ID: 1D100115833303443051E32BC64254CBBEE112FB
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH:
    25B977A055BE9B5DEC0C38A2A279C695
    CMT ROM ID: 3E273BF637BE26FA
    Loading CMT secondary boot code
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 11872E91
    FUR: Adding Asic CMT as client OK.
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35421203127556_CE RT.rpl"
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 181.06 MB
    CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
    CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
    CMT FLASH,MuxOneNAND area [008E0000-0B93FFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT SOS+PMML block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 397DCE21 [RAP Certificate 210 v1] sent
    CMT GENIO_INIT block sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT LDSP block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    Programming completed in 22.610 s
    Processing PPM file: rm566_031.022_17.01_Vietnam_prd.rofs2.fpsx
    [BB5,XSR 1.6] size: 30.08 MB
    Erase size: 51 MB
    CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF]
    CMT SOS+ROFS2 block sent
    Programming completed in 8.125 s
    Processing PPM file: rm566_031.022_C01.01_BLACK_prd.rofs3.fpsx
    [BB5,XSR 1.6] size: 8.36 MB
    Erase size: 25 MB
    CMT FLASH,MuxOneNAND area [0A040000-0B93FFFF]
    CMT SOS+ROFS3 block sent
    Programming completed in 2.406 s
    Processing CNT file: rm566_031.022_U000.000_prd.uda.fpsx
    [BB5,XSR 1.6] size: 528.28 KB
    Erase size: 61 MB
    CMT FLASH,MuxOneNAND area [0B940000-0F63FFFF]
    Programming completed in 0.625 s
    Total time for flashing process(boot+erase+write) was 46.391 s
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
    Jan 2011
    mình Flash là nó báo nhu vậy đó..........
    Jan 2011
    anh em giúp mình với............
    Jan 2009
    Hải Phòng
    thử flash dead usb xem dc ko rồi tính tiếp.
    Thành viên tích cực QUỐCTHANG_MOBILE's Avatar
    Apr 2010
    bạn cho wa mxbox thử xem sao bạn, máy tình trạng ban đầu như thế nào bạn cho thêm chút thông tin đi.
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Kiếm file RPL của máy bình thường,xóa bỏ phần NPC đi rồi write vào
  1. Trả lời: 5
    Bài viết cuối: 27-08-2013, 08:32
  2. Trả lời: 5
    Bài viết cuối: 18-12-2012, 16:58
  3. Trả lời: 10
    Bài viết cuối: 06-08-2012, 12:26
  4. 6730 chay phoenix bao loi ....
    By chuminhtruong55 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 15-03-2011, 07:09
  5. Trả lời: 25
    Bài viết cuối: 27-01-2010, 16:24
