    Thành viên chính thức thaotanmobile's Avatar
    Exclamation 2700c lên nguồn lại khởi động lại!!!!!!!!!
    LOG CUẢ NÓ DÂY, MONG ACE GIÚP MỘT TAY-CẢM ƠN RẤT NHIỀU!!
    Version from phone: 09.98
    Version from file: 09.98
    MXKEY Serial: [FT SCR2000 0] - C08487D0
    Connection status: UHCI:HUB:USB 1.10 (Full-speed)
    Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
    Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
    Reading Important data ...
    Reading RPL backup ...
    Reading Secure Storage ...
    Reading SIMLOCK data ...
    Reading CERT data ...
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 1D500218734700567F40EBBED10A05D01C36DB16
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    eBB5ProtocolType: OLD
    ID 32: 000110040C00
    TransmissionMode: 16Bit
    No RAP Flash Chip Detected
    TransmissionMode: DDR&TX2
    Reading CMT CCC (0x6B44 bytes).
    Flash Imei: 35337604464173
    NPC_DATA saved OK
    CCC_DATA saved OK
    SIMLOCK_DATA saved OK
    SIMLOCK_KEY_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    CMLA_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    LOCK120_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35337604464173_BA CK.rpl"
    Processing MCU file: rm561__09.98.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ID 32: 000110040C00
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.578 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.125 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.016 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 0.204 s
    CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 7.625 s
    CMT FLASH,NOR area [01380000-0151FFFF] erased in 6.781 s
    Prog.status for Asic CMT ...
    NOR: Success
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: Success
    Programming completed in 13 min 24.641 s
    Processing PPM file: rm561__09.98.ppm_t
    [BB5,BB5 ALGORITHM] size: 6.62 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ID 32: 000110040C00
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF] erased in 28.953 s
    NOR: Success
    NOR: Success
    Programming completed in 4 min 58.282 s
    Processing CNT file: rm561__09.98.image_ctv_nz_gray
    [BB5,BB5 ALGORITHM] page size: 128 K size: 10.89 MB
    NOR page size in the phone is 128 K.
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ID 32: 000110040C00
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 15.625 s
    CMT FLASH,NOR area [02160000-03FBFFFF] erased in 2 min 4.984 s
    NOR: Success
    Converting UCP blocks to 128 K.
    NOR: Success
    Programming completed in 7 min 27.672 s
    Total time for flashing process(boot+erase+write) was 30 min 38.485 s
    Phone type: RM-561 (Nokia 2700 classic)
    SW version: V 09.98 06-09-10 RM-561 (c) Nokia
    Imei plain: 35337604464173-3
    Product code: 0579808
    Battery voltage: 4851 mV, current: 21 mA
    Language Pack:
    - not available.
    Detected as PA_SL3 phone.
    - Avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 353376044641733
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.937 s
    Thành viên tích cực anh tú_gsm's Avatar
    Jan 2011
    hạ hòa - phú thọ
    coi lại con plash nhé
    ĐIỆN THOẠI DI ĐỘNG ANH TÚ - KHU 17 - ĐẠI PHẠM - HẠ HÒA - PHÚ THỌ. ĐT: 0985 69 0949
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    chưa nhận flash
    Jan 2012
    bachkup thay flat don
    manhdung81mobile@gmail.com
    Apr 2010
    xem lại cáp đi đưa qua hợp khác flash đi nếu không được con RAP hoặc con FLASH bị hở chân rồi đó
    Thành viên chính thức Tuấn Tân Trụ's Avatar
    huyện tân trụ
    flash đi bạn
    Nhẫn một chút sóng yên gió lặng.0973.
    Lùi một bước biển rộng trời cao. 286.172
    No RAP Flash Chip Detected có vấn đề này đụng nóc cho em nó cái đi anh
    chủ tài khoản: TRẦN VĂN SƠN
    TK MB : 9990 1113 95201
    VCB :0021.000.296.541
    yahoo : TVS_88
  1. Trả lời: 12
    Bài viết cuối: 30-09-2012, 04:37
  2. 2700c lên rồi sụp nguồn
    By vinhls in forum BB5
    Trả lời: 19
    Bài viết cuối: 25-03-2012, 09:02
  3. Trả lời: 9
    Bài viết cuối: 20-11-2011, 14:58
  4. Trả lời: 14
    Bài viết cuối: 30-08-2011, 09:35
  5. 2700c mở nguồn không lên
    By hung345 in forum BB5
    Bài viết cuối: 25-04-2011, 14:52
