Kết quả 1 tới 3 của 3
    Thành viên mới timtim123's Avatar
    Feb 2012
    Mặc định N70 rớt nước mất nguồn check báo lỗi
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 7], SN: C0859233
    Using device: HTI, FW ver: 00.24, SN: 0001602D
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    APE Data :
    SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
    ASIC MODE ID: 00
    PUBLIC ID: 19641DC3DDB26C2A3B44F4EA7121938C5724BEBB
    ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
    ROM ID: AB5E4ADB27A06946
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 1450010E0F105F51D9DF97F1610E3AA0B40B97E9
    ASIC MODE ID: 00
    ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
    ROM ID: F28A211FCEA7B19D
    SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
    Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
    eBB5ProtocolType: OLD
    Storage0: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
    TransmissionMode: 16Bit
    No RAP Flash Chip Detected
    TransmissionMode: DDR&TX2
    SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
    Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
    Storage0: 0098 0036 - 00A5 00C0 [Toshiba 512 DDP NAND,512 Mbits] type: FLASH,NAND, asic:APE
    Suggested algorithm: OMAP1610 GBBM-1.8.1 ALG
    Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
    Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908
    APE PAPUBKEYS is blank/erased.
    Original Imei: 00000000000000
    Original Product code:
    đã làm chân flash mà tình hình vẫn ko thay đổi ,bạn nào biết xin giúp đỡ
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    thay cặp rồi pro ah
    Feb 2012
    dòng này thay cặp chua hơn chanh nữa ,
  1. 5800 mất nguồn check lỗi
    By mvu401 in forum BB5
    Bài viết cuối: 14-05-2013, 19:29
  2. Trả lời: 15
    Bài viết cuối: 31-03-2013, 23:33
  3. Trả lời: 5
    Bài viết cuối: 04-10-2012, 20:46
  4. 6100 mất nguồn check ok flash mất nguồn
    By kim nhut truong in forum DCT4 - WD2
    Bài viết cuối: 13-12-2009, 21:28
