BUY GEVEY SIM AIO V2
(NO CUT Version) + GEVEY DONGLE
FREE DELIVERY WORLDWIDE
GEVEY SIM AIO CUT ONLINE UPDATE V2.9
and
GEVEY SIM AIO UPDATE V19 – T-Mobile and others
GEVEY SIM AIO Configurator V2
We are happy to announce the release of
GEVEY AIO ONLINE UPDATE V2.9.
Using this version you can update your GEVEY AIO with the
FIRST in the world UPDATE 19 that includes the GID1 setting.
This version is similar in function with the already released version
for the NO CUT GEVEY AIO TYPE V1.6 and is
FREE for all GEVEY AIO CUT TYPE users!
GEVEY AIO UPDATE V19 – T-Mobile and others – FIRST IN THE WORLD
FIRST IN THE WORLD
– supports all 5.1 and 5.1.1 iPhone 4S modem versions
FIRST IN THE WORLD
– supports all phones with and without GID1 locks
FIRST IN THE WORLD
- tested on T-Mobile Germany iPhone 4S 5.1.1 and 5.1 (modem 2.0.12)
supports IMSI modifications
FIRST IN THE WORLD (from previous version)
- supports ICCID modifications
(must be programmed with the correct ICCID)
GEVEY AIO CUT ONLINE UPDATE V2.9 Features
- The software can now read and check GID1 service table field
from any simcard WITHOUT PIN code
- The software can now read the contents of GID1 field
- The software can now program a variable length GID1 (up to 7 bytes)
to any GEVEY CUT programmed with UPDATE V2.9 or
any future update that supports GID1 setup
The unlock procedure using GEVEY SIM AIO UPDATE V19
1. Program your GEVEY using the correct IMSI, ICCID and GID1
1.1 IMSI – You need to program it using the IMSI of the original network
where you iPhone is locked. It is a good idea to read IMSI, ICCID and GID1
from your original simcard (if you have that) and use this settings;
1.2 ICCID – if our online application GEVEY AIO Configurator
recommends that you use ICCID for your phone then please edit your
ICCID to match the recommendations; If ICCID is not required then please
READ the ICCID from the simcard you are planning to use with GEVEY
(NOT the original simcard, YOUR SIMCARD) and use that IMSI;
1.3 GID1 – only few phones are required to have a valid GID1 value.
Only use GID settigs if our online application
GEVEY AIO Configurator recommends that
2. insert GEVEY together with your simcard in a powered on phone
and wait for about 2 minutes
3. if you have problems in using the data connection please try to make
the appropriate settings using our online application
GEVEY AIO Configurator.
Visit this application using your iPhone browser !
THE GEVEY AIO Configurator V2
You can find the GEVEY AIO Configurator here GEVEY AIO Configurator
What does the options mean ?
1. Stored Network settings is a FIRST IN THE WORLD option
(you can use this option from any browser, including iPhone)
are the recommended settings you can use into your
GEVEY ONLINE UPDATE software.
We have removed this settings from the software in order to keep only
one update ONLINE version found .
After you use this option you will see a screen with the following informations
(let’s say you choosed T-Mobile DE from the list )
Country: DE
Network: TMobile
IMSI: 26201
(this means that the IMSI used in GEVEY ONLINE UPDATE software
MUST start with this 5 digits if you want to get the phone unlocked )
ICCID:
No specific requirement (this means that the ICCID used in GEVEY
ONLINE UPDATE software MUST start with this digits if you want to
get the phone unlocked, in this case there is no specific requirement )
GID1:
No specific requirement (this means that the GID1 used in GEVEY
to get the phone unlocked, in this case there is no specific requirement)
HAS profile:
Does not have a profile attached (if you want to apply on the phone
the default settings use on this network then you can use this option
if it’s available, use this option while browsing this page using iPhone 4S
browser, won’t work from normal browsers)
Notes:
please use this settings and post results
IMSI: 262012830169393
ICCID: 89490200000534066399
GID1: 71
Notes are very important!
Please follow them and post results on our forum!
2. Manual APN Settings enables you to automatically apply your
desired settings into your iPhone 4S simple and easy
3. Stored APN settings in order to help you we have made the most
complete list of APN settings on the internet and gave direct access
to you so you can setup you iPhone 4S with only a few clicks
One last request! Please post on our forum errors
regarding the GEVEY AIO Configurator.
We want to make it the most complete and correct reference tool
for your unlocking needs and we need your help !
GEVEY SIM AIO Version 2.9 for GEVEY AIO CUT links:
1. UpdateV2.9.zip
2. UpdateV2.9.zip
3. UpdateV2.9.zip
4. UpdateV2.9.zip
5. UpdateV2.9.zip
IMPORTANT INFO:
How to use your GEVEY after FREE UPDATES are over ?
- If you have already completed FREE updates your GEVEY will be stuck in UPDATE MODE.
- If you press the Read SN button the software will read the SN from your GEVEY
and also restore your GEVEY to the last working state.
- So if your GEVEY was updated with version xx on last successful update,
by using
Read SN button you will be able again to use that version
!! ATTENTION !!
If your GEVEY stopped updating during the
UPDATE procedure because of a FAILURE
DON’T USE THE READ SN BUTTON TO GET
YOUR GEVEY OUT OF UPDATE MODE !!
If you do that it might render your GEVEY UNUSABLE
if the last update WAS NOT SUCCESSFUL.
So you can use this button to get your GEVEY out of UPDATE MODE only if your GEVEY
reached the maximum number of FREE updates !
BUY GEVEY SIM AIO V2 (NO CUT Version) + GEVEY DONGLE
			 WORLD 1ST UPDATE V19 – TMobile & others, GEVEY CUT V2.9, GEVEY AIO Configurator V2
