    Thành viên mới ytudtu's Avatar
    Mặc định x2-01 trắng màn khởi động lại
    AE xem cho mình cái log con x2-01 chay MxKey
    MXKEY [FT SCR2000 0], SN: C0839DE4
    Using device: USB ROM
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    Processing MCU file: rm709__08.70.mcusw
    [BB5,XSR 1.6] size: 26.61 MB
    Supported Ids: 2200050920030000, 22000509200C0000
    Waiting for USB ROM device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1A7D6778
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 0000000000CF08E8B2DF8A39B3BB69A82DE40BF3
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    FUR: Adding Asic CMT as client OK.
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35974304949759_CE RT.rpl).
    CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
    Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 33.88 MB
    CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
    CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
    CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
    Formating partition ...
    Flash programming ...
    CMT KEYS block sent
    CMT ADA block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 37955B6F [] sent
    CMT UPDAPP block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 13.656 s
    Processing PPM file: rm709__08.70.ppm_t
    [BB5,XSR 1.6] size: 6.80 MB
    Erase size: 8 MB
    CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
    Programming completed in 3.672 s
    Processing CNT file: rm709__08.70_003.image_t_ctv_ph_9g4b0
    [BB5,XSR 1.6] size: 29.05 MB
    Erase size: 75.31 MB
    CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
    Programming completed in 15.406 s
    Processing MMC file: rm709__08.70_sd_empty.fpsimage
    [BB5,XSR 1.6] version: 0.0.0 size: 287.33 KB
    Supported Ids: 22000509200C0000, 2200050920030000
    No Erase header defined, erase will be skipped
    Erase skipped.
    Programming completed in 0.094 s
    Total time for flashing process(boot+erase+write) was 46.984 s
    [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
    Device connected: nmwcdc\Nokia X2-01 USB Phonet, PORT_ID: 23022031
    Verifying communication to device OK.
    Phone type: RM-709 (X2-01)
    SW version: V 08.70 29-07-11 RM-709 (c) Nokia
    Imei plain: 35974304949759-9
    Product code: 059G4B0
    Battery voltage: 3801 mV, current: 162 mA
    Language Pack:
    - not available.
    Camera config: NI00BC00000401022C00, ver: 003.006
    SIMLOCK seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 359743049497599
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    chạy xong vẫn bệnh cũ
    Feb 2008
    lâm đồng
    thao camera rùi thử test coi sao bạn hôm bũa gặp 1 em ok
    D/C: LÂM HÀ_SUCCECSS_
    AGRIBANK-NGUYỄN NGỌC PHONG
    T/K ;5404205189065
    Vi phạm nội quy truccau1990's Avatar
    Jan 2011
    liệu em nó có liên quan tới cái này ko , xem có giúp đc gì cho bạn ko : http://saigonmobile.vn/forum/bb5/116...-man-hinh.html
    đã thử 2 cách mà vẫn không được AE nào còn cao kiến nữa không . Thank !
    Nov 2010
    đưa qua box khác flash lại thử xem
    mx đôi lúc cũng bị khùng
  1. 3gs zon trắng, càm ứng trắng không mất cảm quang
    By phongchaumobile in forum iPHONE 3Gs
    Bài viết cuối: 06-06-2013, 13:04
  2. Trả lời: 3
    Bài viết cuối: 15-06-2010, 11:52
  3. Trả lời: 7
    Bài viết cuối: 23-04-2009, 17:02
