Kết quả 1 tới 10 của 18
    Thành viên kỳ cựu ♠mobilebien™♂'s Avatar
    Nov 2011
    Mặc định 2730c flash nháy chớp nguồn
    như tiêu đề em flash by mxbox các kiểu chỉ đc như vậy, bật nguồn lên như kiểu mất mei ,nhờ ae xem dùm log.. ae giúp dùm em nhá..thanks.
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0859F85
    Using device: HTI, FW ver: 00.50, SN: 0000C4B5
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006030C192101023000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 1F60010EA3480456121BE92E7BAFC3F329E8FDC1
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1
    TransmissionMode: DDR&TX2
    Processing MCU file: rm578__10.45.mcusw
    [BB5,BB5 ALGORITHM] size: 21.65 MB
    Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
    Erase size: 23.25 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0155FFFF]
    CMT FLASH,NOR area [01560000-0175FFFF]
    erased in 2 min 19.031 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 8669C775 [RAP Certificate 215 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 37.375 s
    Processing PPM file: rm578__10.45.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.78 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01760000-01FFFFFF]
    erased in 42.563 s
    NOR: OK
    NOR: OK
    Programming completed in 29.454 s
    Processing CNT file: rm578__10.45.image_v_red_v2
    [BB5,BB5 ALGORITHM] page size: 128 K size: 15.64 MB
    Erase size: 31.75 MB
    CMT FLASH,NOR area [02000000-0245FFFF]
    CMT FLASH,NOR area [02460000-03FBFFFF]
    erased in 2 min 20.875 s
    NOR: OK
    NOR: OK
    Programming completed in 1 min 7.219 s
    Total time for flashing process(boot+erase+write) was 8 min 46.469 s
    Nơi làm việc: kythuatphone.vn
    Nov 2011
    còn đây là em BUSS check
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Selected firmware certificate matched.
    Original Imei: 35623404325235
    Original Product code: 059C0H1
    Bluetooth ID: D82A7E152083
    SIMLOCK PA identifier:
    [0] PA_SL3
    Thành viên tích cực anh tú_gsm's Avatar
    Jan 2011
    hạ hòa - phú thọ
    cho vào box khác plash thử coi sao. vẫn vậy thì kiểm tra cặp anh nhé
    ĐIỆN THOẠI DI ĐỘNG ANH TÚ - KHU 17 - ĐẠI PHẠM - HẠ HÒA - PHÚ THỌ. ĐT: 0985 69 0949
  4. ( anh tú_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ♠mobilebien™♂ (22-05-2012)
    Jan 2011
    hạ hòa - phú thọ
    Original Imei: 35623404325235 , đẹp như gái 18 không phải Imei đâu
  6. ( anh tú_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Nov 2011
    em chỉ có mxbox,JAF. em đã làm các kiểu bằng box đó và USB
  8. #6
    Thành viên tích cực QUỐCTHANG_MOBILE's Avatar
    Apr 2010
    cái này anh lấy cáp đa nang mà chạy ok ngay, chạy usb không được đâu em đã test rùi ok. chúc anh thành công.
    trên đời không gì là không thể.
  9. ( QUỐCTHANG_MOBILE ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  10. #7
    Nov 2011
    Trích Được post bởi QUỐCTHANG_MOBILE Xem bài viết
    đã tet đa năng đời cũ đời mới fb3 đều not ok. máy vẫn lên kiểu như mất mei
  11. #8
    vừa hôm wa mình cúng làm 1 chú như thế cú chạy bào lock ok hết ma bật nguồn lúc thì lên nokia rồi tắt luc lai sai dc khoảng 10p a thủ chạy vẻ cao nhất .....đá nhà lầu xong lại chạy lại lần nửa xem dc ko a
  12. ( hachanyen ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #9
    Feb 2008
    lâm đồng
    thử phonenix bit đâu hên sui bạn
    D/C: LÂM HÀ_SUCCECSS_
    AGRIBANK-NGUYỄN NGỌC PHONG
    T/K ;5404205189065
  14. ( phongchinhphuc_pro™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  15. #10
    a e va các mod ai co kinh nghiệm hay chia se dóng 2730,2700,5130 nhửng bệnh tráng treo chóp tắt mong ae up dùm
  16. ( hachanyen ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. 2730c Rớt Nước MẤt Nguồn.......
    By quythongay in forum BB5
    Bài viết cuối: 07-11-2014, 16:19
  2. 2730c-1 lên chữ nokia rồi trắng màn hình ko flash dc xin giúp
    By binhokls in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 13
    Bài viết cuối: 02-02-2013, 10:00
  3. 2730c Đang Flash cúp điện !
    By PhùngMobile in forum BB5
    Trả lời: 25
    Bài viết cuối: 06-05-2012, 10:48
  4. 2730c rớt nc mất nguồn
    By qkmobile_kcr in forum BB5
    Bài viết cuối: 07-11-2011, 18:02
  5. 2730c nạp đứng mất nguồn
    By nguyendong_mobi in forum BB5
    Bài viết cuối: 05-10-2011, 12:24
