Mcnpro Light Box dựa trên Mcn Box phát triển, thiết kế lại phần cứng để có được sự ổn định hơn, phương pháp mới để tự động pinout scaning chỉ trong vài giây.
Support all chinese mobile chips such as MTK, ADI/AD, Spreadtrum, Skyworks, TI(Texas Ins), Infineon, AGERE, OM(Philips), Anyka, CDMA etc.
Pinfinder was included, Support automatical identification ,Scan the phone's pinouts definition in few seconds.
Built-in USB detection chip which make USB detection the phone more fast and more accuracy.
Negative / positive can be converted fully automated. It is more convenient to detect tail socket.
High speed serial port PL2303 and FT232 and 24pins COM which makes route unlimited.
Scan VCC, GND, TXD, RXD and high-voltage startup route (or low-voltage startup route).
Perfect over-voltage protection hardware design
Automatic box hardware upgrade /repair function supported
MTK(Mediatek) CPU
All MTK CPU based models support
Write/Read (Backup) Full flash for phones
Write/Read (Backup/ Restore) NV data for phones
Write/Read eeprom for phones(MTK Nor flash)
Write/Read firmware for phones(MTK Nor/Nand flash)
Smart Write function fast for flash phones(MTK Nor)
Automatic fix SMS backdoor (First in the world)
Normal Format phone(Can backup LCD data before format)
Manual Format phone(Can backup LCD data before format)
Safely Format (SSF) phone(Can backup LCD data before format)
Touchscreen calibration (repair phones with damaged touchscreen)
Can backup LCD data before format after write LCD data back to fix calibration issue
Can repair "No licensed to produce"
Direct unlock User/Pf code for phones
Direct read unlock User/Pf code from firmware, no need connect phone
Automatic firmware version detection and save original firmware version information in Log file during flash/format
Automatic CPU/ Chips infomation detection
Automatic repair/recalculate security area
Upgrade/downgrade phone firmware
Repair software-related problems
Via flash to repair dead phones
Repair "Bad Software" fault for all MTK Cpu based models
Can Empty board flashing(After flash chip replacement)
Save operation process results in Log file
Can backup/write Phone book by txt file
Reset phone settings to defaults (factory state)
Read/write IMEI for all MTK based models
SPD(Spreadtrum) CPU
All Spreadtrum CPU based models support
Format phone automatic or manual format both support
Direct unlock User code phones
Direct read unlock User code from firmware, no need connect phone
Reset phone settings to defaults (factory state) when flash
Read/write IMEI for all SPD based models during flash
Read Phone book direct from file
INF(Infineon) CPU
7850 7870 7880 Infineon CPU based models support
Automatic repair/recalculate SIM LOCK
AGE(AGERE) CPU
AGERE CPU based models support
Anyka CPU
3224 CPU based models support
Si4904 CPU
AMD/SAMSUNG INTEL CPU based models support
Allow don't change IMEI during flash
ADI/AD CPU
MSP430 Herc/Hermes CPU based models support
SKY(Skyworks) CPU
SKY CPU based models support
TI (Texas Ins) CPU
TI CPU based models support
OM (Philips) CPU
OM(Philips) CPU based models support. eg, 5212UP etc
CDMA (QUALCOMM)
Mstar CPU
Write/Read (Backup) Full flash (Nor/Nand) for phones
Format phone by automatic or manualy
Read/write IMEI (First in the world)
AD6905 CPU
Read/write IMEI for all AD6905 based models
			 MCN ra mắt sản phẩm mới Mcnpro Light Box
