Kết quả 1 tới 10 của 12
    Thành viên tích cực binhtuyen's Avatar
    Jun 2011
    Mặc định 1208 chạy phần mềm báo lỗi nhờ ae giúp
    đây là log của em no
    MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0873ED7
    Using device: HTI, FW ver: 00.50, SN: 0100D01C
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    ASIC ID: 0x2292 [UPPCosto ver: 1.3]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
    UEM ID: 009713E8A3BDA66
    ASIC type: 11
    UEM Imei: 35434704570109
    Flash Imei: 35434704570109
    RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35434704570109_BA CK.rpl"
    Processing MCU file: rh105_05.910
    [DCT4,DCT4 ALGORITHM] size: 2.28 MB
    Supported Ids: 2292
    UEM ID: 009713E8:2984DA60
    Area [01000000-0100FFFF] erased in 0.660 s
    Area [01010000-013AFFFF] erased in 33.385 s
    Area [013B0000-013EFFFF] erased in 2.519 s
    Area [017C0000-017EFFFF] erased in 0.019 s
    Area [01FC0000-01FEFFFF] erased in 0.020 s
    Flash programming ...
    Programming completed in 19.470 s
    File Processed in 1 min 2.525 s
    Processing CNT file: rh1050_nai5.91mr
    [DCT4,DCT4 ALGORITHM] size: 139.53 KB
    Supported Ids: 2292
    Area [01380000-013AFFFF] erased in 1.765 s
    Programming completed in 1.183 s
    Content extract fail, continue anyway ...
    File Processed in 38.763 s
    Processing PPM file: rh105_05.91mr
    [DCT4,DCT4 ALGORITHM] size: 1.20 MB
    Supported Ids: 2292
    Area [01240000-0124FFFF] erased in 0.558 s
    Area [01250000-0137FFFF] erased in 10.973 s
    Programming completed in 10.236 s
    File Processed in 28.187 s
    Total time for flashing process(boot+erase+write) was 2 min 9.483 s
    Mar 2012
    nam định
    cho qua jaf chạy lại.not ok thì xóa full flash nap lại+write pm+unlock=done
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
  3. ( A & T Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    binhtuyen (23-05-2012)
    Jun 2011
    em chỉ có mx bõ thôi em có cách nào xử em này nữa ko giúp em với
    V.I.P anhvanmobi's Avatar
    vệ sinh lại điểm tiếp xúc + kiểm tra lại cáp xem
    CH . HẠ LONG - Mobile Service Center - ĐT: 0373 566 808 - 0982 267 789. ĐC: 162 . Phố. Giắt. TT Triệu Sơn. Thanh Hóa
  6. ( anhvanmobi ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Apr 2010
    lấy hwk mà múc là ok với xem lại file nhé anh bạn.không hết xóa full chạy lại nhé
  8. ( KHA_MOBILE67 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Mar 2012
    nam định
    chủ thớt kêu chỉ mx box thôi.nếu k có box nào nữa thì dùng mx box xóa flash đi rồi chạy cũng dk
  10. #7
    Jun 2011
    Trích Được post bởi khocvole Xem bài viết
    em xóa full nạp lại rồi nó vẫn vậy
  11. #8
    Thành viên chính thức ninhmobile825's Avatar
    Feb 2012
    vịnh bắc bộ
    che 1 chân chạy đi bác tháo máy ra WC cái rồi chạy. không đc đá ic nguồn cái
  12. ( ninhmobile825 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #9
    Thành viên tích cực sang_apple's Avatar
    Feb 2012
    F,3 Q4 ,Hồ Chí Minh
    bạn bỏ wa box khác chạy ver đụng nóc nha
    Luôn lắng nghe và học hỏi....
  14. ( sang_apple ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  15. #10
    Jan 2009
    Hải Phòng
    cái này chạy xong không đồng bộ thôi,: xóa full , che chân vpp lại flash là dc
  16. ( tuân gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. 1208 bi chạy lại phần mêm contecservei
    By toantkx92 in forum DCT4 - WD2
    Bài viết cuối: 11-04-2012, 07:57
  2. Trả lời: 0
    Bài viết cuối: 26-02-2012, 13:32
  3. phần mềm 1208 cần giúp
    By gialong113 in forum DCT4 - WD2
    Bài viết cuối: 22-01-2011, 21:37
  4. Thảo luận cách chạy phần mềm và sự cố trong lúc chạy phần mềm
    By KIM HUNG in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-05-2008, 20:38
