    Thành viên chính thức khuvuckythuat's Avatar
    Dec 2011
    Mặc định x2-01 báo pin yếu contassevic
    mình mới thay ic upp của x300 vào x2-01 thì máy báo pin yếu va contat s.. rui tat may.ae co giai pháp nào đồng bộ hướ dẫn mình vói nhé
    Apr 2010
    đưa vào box xem như thế nào ime còn không anh bạn mình
    Dec 2011
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 00006DC2
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: NMWCD, ver: 7.1.32.73
    Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
    Processing MCU file: rm709__08.70.mcusw
    [BB5,XSR 1.6] size: 26.61 MB
    Supported Ids: 2200050920030000, 22000509200C0000
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 00000000002EB05447DC16B9BF15C08106030040
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
    Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 20CC1644
    FUR: Adding Asic CMT as client OK.
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35484204256510_CE RT.rpl).
    CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
    Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 33.88 MB
    CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
    CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
    CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
    Formating partition ...
    Flash programming ...
    CMT KEYS block sent
    CMT ADA block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 37955B6F [] sent
    CMT UPDAPP block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 8.187 s
    Processing PPM file: rm709__08.70.ppm_t
    [BB5,XSR 1.6] size: 6.80 MB
    Erase size: 8 MB
    CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
    Programming completed in 3.047 s
    Processing CNT file: rm709__08.70_003.image_t_ctv_ph_9g4b0
    [BB5,XSR 1.6] size: 29.05 MB
    Erase size: 75.31 MB
    CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
    Programming completed in 13.281 s
    Processing MMC file: rm709__08.70_sd_empty.fpsimage
    [BB5,XSR 1.6] version: 0.0.0 size: 287.33 KB
    Supported Ids: 22000509200C0000, 2200050920030000
    No Erase header defined, erase will be skipped
    Erase skipped.
    Programming completed in 0.047 s
    Total time for flashing process(boot+erase+write) was 34.109 s
    Device connected: nmwcdc\Nokia X2-01 USB Phonet, PORT_ID: 38A74221
    Verifying communication to device OK.
    Phone type: RM-709 (X2-01)
    SW version: V 08.70 29-07-11 RM-709 (c) Nokia
    Imei plain: 12345610654321-?
    Product code: 059C3M1
    Battery voltage: 3723 mV, current: 1 mA
    Language Pack:
    - not available.
    Camera config: NI00BC00000401022C00, ver: 003.006
    SIMLOCK invalid!
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei plain is invalid !!!
    SIMLOCK_DATA corrupted!
    FULL FACTORY... Failed! (0016)
    Completed in 21.031 s
    đây là nvo wa bõ đó .ae giùp m nhé
    Apr 2010
    ime như thế là banh rồi Imei plain: 12345610654321-?...sim SECURITY_TEST failed! cũng lỗi luôn rồi nhé..gửi log thì cao tiền lắm tìm cập của nó mà hay vào nhé
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Giải pháp duy nhất là thay cặp.
    Nếu ở Hanoi thì đang nhiều cặp cho bạn.
    May 2011
    Hà Nội City
    SIMLOCK invalid!
    SIMLOCK_TEST passed
    Thay cặp nhé Pro
    Dec 2011
    ơ đâu bán cặp vây ae. cho mình địa chỉ đươc không
