What's new for Mcnlight box version 1.2.0.9 ? New!! Hot!!
- Add CoolSand CPU Read function
- Add CoolSand CPU Write function
- Add CoolSand CPU Format function
- Add CoolSand CPU Unlock function
- Add CoolSand CPU IMEI Change Function (First in the world)
- Improved MTK 6573/6516/6513 read /write
- Fix Nor flash write bugs for boot6
- Fix MTK safe format issue
- Improved Tubro mode flash phone speed
- Improved MTK USB Pin-find function
- Improved Spreadtrum 6800H read /write
- Add support Spreadtrum 880xG
- Improved Spreadtrum direct IMEI change function
- Spreadtrum new Flash ICs added
- Fix Mstar read /write bugs
- Other small report bugs fixed
Code:
22:24:46 Welcome to use McnPro light Box 22:24:46 Baud setting ... 22:24:51 Set Baud done 22:24:51 SW V12.09 22:24:51 FW V2.04 22:24:51 SN MCNL8888888888888 22:24:51 AC 8888-8888-8888-8888-8888 22:24:51 Box Connected!
Upgrading from Previous Versions:
- As usual, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section !
>>>>> Read more...
Best regards !
Mcnbox
