Kết quả 1 tới 4 của 4
    Thành viên chính thức DINH_PHÁT_MOBILE™'s Avatar
    Dec 2011
    Mặc định các bác xem giùm log n97 mini
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C08728FF
    Using device: HTI, FW ver: 00.50, SN: 00006502
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 0540010351860052E151FEFE62B31A55D51AD27A
    ASIC MODE ID: 00
    ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
    ROM ID: 4B9B75103E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.2.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0058 - 0000 0121 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.2.0 revision: 2.0 size: 0x8B45D
    CMT PAPUBKEYS HASH: C49131EB98702B6A39D7F285B1FF2D9BE1D6F863
    Original Imei: 35831503717346
    Original Product code: 0591466
    Bluetooth ID: C8979F7B1DCE
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Phone type: RM-555 (Nokia N97 mini)
    SW version: V ICPR72_11w18 09-05-11 RM-555 (c) Nokia
    Imei plain: 35831503717346-5
    Product code: 0593106
    Battery voltage: 4283 mV, current: 56 mA
    Language Pack:
    - not available.
    Imei net: 358315037173465
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    như vậy mà nó lên nguôn chỉ trắng màn 20s rồi tự đen màn hình rồi tắt...............
    Thành viên tích cực HOÀNGTRUY_GSM's Avatar
    Jan 2011
    Cần Thơ
    Bác đag chạy ver mấy vậy?đưa qua box khác thử xem
    Vi phạm nội quy truccau1990's Avatar
    Jan 2011
    N97 + N96 Flash tấc ngơ lắm . huynh chạy die USB JAF đi .
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    flash cho nó phát xem
  1. N97 mini mất chân sim
    By tinny in forum BB5
    Bài viết cuối: 09-01-2013, 16:06
  2. Hướng dẫn cắt sim Mini->Micro, Mini->Nano, Micro->Nano cho iphone 5
    By 5ncnow.com in forum SƠ ĐỒ & GIẢI PHÁP SỬA CHỮA PHẦN CỨNG
    Bài viết cuối: 11-10-2012, 14:08
  3. ae hướng dẩn giùm e cách repait boot con ss s5230 giùm e với
    By truong25071990 in forum Phần mềm Samsung
    Bài viết cuối: 14-01-2012, 14:57
  4. cần anh em chỉ giùm updat model giùm
    By tranquocthangts in forum J.A.F
    Bài viết cuối: 07-06-2011, 13:06
  5. Nhận direct unlock cho X10, X10 Mini, X10 Mini Pro, X10 Docomo ( SO-01B ), E15, X8, U20 Xperia Mini pro, M1 Aspen, W100
    By saigonmobile in forum Dịch vụ unlock trực tiếp điện thoại di động
    Bài viết cuối: 03-06-2011, 09:57
