Kết quả 1 tới 10 của 26
    Thành viên chính thức trangpt1's Avatar
    Mar 2012
    Mặc định 5530 RM-504 chạy Phần mền ok nhưng không lên.Help
    Em thay cặp CPU+flash nokia5530, Dùng Phoenix chạy lại ver cao nhất chạy xong ok màn hình lên và báo loca mode ok
    Nhưng bật nguồn chỉ rung phát.tối om!
    em buscheck bằng atf thì log là
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 400C1921
    ID DWORD 4 : 01051105
    2 ROM_ID 15
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 ROM_ID 15
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 15A00005
    ID DWORD 1 : 7B800052
    ID DWORD 2 : C9569887
    ID DWORD 3 : F4B9A809
    ID DWORD 4 : 1C1375C7
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : B8 C3 AD EC FC 99 7F CD 80 81 D3 DE AF 87 0B 8C
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 4B9B7510
    CRC 1 : 3E691FF8
    Checksum 13
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
    Boot File - Version 011.016.00
    Boot File - Revision 0x0002 (2)
    eBB5ProtocolType == New
    PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
    PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
    Secondary Loader Sent...
    TransmissionTypeRequest_DCT5_NewProtocol
    TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
    FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
    Transmission Type Request Sent...
    MessageID : 06
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> not detected
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0020 ->
    Device ID : 0040 -> Type not in database
    Revision ID : 0031
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> not used
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Revision ID : 0031
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.5
    Checksum : 55
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
    Algorithm File - Version 011.016.00
    Algorithm File - Revision 0x0002 (2)
    Algo Loader Sent...
    SendCodeStart_NewProtocol :
    SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok...
    VPP Enabled by Software
    Using Internal VPP
    FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    F2B05364E563A348608C1C3C9E54FE42AAAA1ACF
    Scanning Simlock Applet Type...
    OK
    PA_SL3 Applet detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    FlashInfo.RestartMode : 2
    Scan phone báo là
    MCU Version: V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia
    IMEI Plain : 358022033857246
    IMEI Spare : A358022033857240
    IMEI SV : 33580220338572419F
    Phone Model: Nokia 5530 XpressMusic
    Product Serial Number: CGK958938
    Product Code : 0578169
    Basic Production Code: 0569346
    Default SN Type : 0
    PPM Version : V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia
    HW Version : 0802
    RFIC Version : 17141715
    DSP Version : ICPR72_10w26p1
    Content Pack Version : v 30.0.001_001_000_U001 05-03-10 vanilla RM504
    AHNE Version : 11
    APE SW Core Version : V 40.0.003
    APE Variant Version : V 40.0.003V 40.0.003 V 40.0.003
    APE Test Version : 09wk19v0.130
    Retu Version : 16
    Tahvo Version : 22
    APE HW Version : 256
    APE ADSP SW Version : 256
    ******** Reading SimLock ********
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider : AT&T;U.S.A. (3650)
    Counters : 0/3 , 0/10
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SP Lock Status : Not Locked
    SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : ENCRYPTED
    PHONE_MODE : LOCAL MODE
    Và chạy bằng ATF cũng chạy hết được!
    nhưng vẫn không lên !
    Nhờ anh em giúp đỡ
    Thank!
    SINH NGHỀ - TỬ NGHIỆP
  1. 5530 chạy phần mềm cần giúp đỡ
    By chuminhtruong55 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 09-09-2012, 15:33
  2. Trả lời: 0
    Bài viết cuối: 26-02-2012, 13:32
  3. nâng cấp 5530 lên c6
    By bvl_2811 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 27-10-2011, 15:29
  4. 5530 chay v40 bị lỗi phần mềm
    By levanhieuqb in forum BB5
    Bài viết cuối: 27-10-2011, 13:03
  5. Trả lời: 7
    Bài viết cuối: 31-03-2011, 08:34
