    Sóc Sơn - Hà Nội
    Mặc định 1280 flash xin giúp
    log của em nó đây ae xem cho : cáp tốt thử trên máy sống ok !!
    MXKEY Serial: [FT SCR2000 0] - C083A07E
    Driver: UFS2XX, ver: 1.5.4.0 , NTMP ver: 1.5.4.1
    Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.14060(05-05-2012)
    Do not disconnect or abort this operation otherwise phone will be damaged.
    Device synchronized.
    CPU: XGOLD 110
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version : Default_RAM_Bootloader
    Set baud rate to: 921600
    Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
    Processing file: rm647_006.510
    Downloading item CODE:hw_b2_rm647_r06.510.fls, num block: 3, size: 4.04 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 33.625 s
    Erasing area 0x00C60000-0x00E5933E ...OK
    Programming completed in 31.907 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.172 s
    Checksum mismatch: Phone calculated 0xA05F, software calculated 0x72AB
    Processing file: rm647_006.51mr
    Downloading item CUST:hw_b2_rm647_006.51mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 17.797 s
    Checksum mismatch: Phone calculated 0x7494, software calculated 0x1507
    Processing file: rm6470_nai06.51mr
    Downloading item CUST:hw_b2_rm6470_nai06.51mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 4.922 s
    Checksum verified (0xA1D0)
    Total time for flashing process(boot+erase+write) was 2 min 52.328 s
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    làm chân lại cặp rồi flash lại anh
    Thành viên tích cực QUỐCTHANG_MOBILE's Avatar
    Apr 2010
    bạn lắc nhẹ u xem rùi flast lại xem sao nhá.
    trên đời không gì là không thể.
    máy lúc đầu bị gì vậy bạn kt có rơi rớt gì ko chạy thử hộp kak chưa ko dc đóng ic nguồn luôn nho 1280 ko la đùng co chay pm full nhé a e biết đùng chém
    Thành viên tích cực sang_apple's Avatar
    Feb 2012
    F,3 Q4 ,Hồ Chí Minh
    Trích Được post bởi VŨ PRO Xem bài viết
    làm như bác Vũ nha bạn
    Luôn lắng nghe và học hỏi....
    Thành viên mới kienvnc's Avatar
    May 2012
    Lucky Lắc---- lắc nhẹ cái chân CPU đi bạn
    Chúc may mắn và thành công !
    0963131080
  1. xin giúp 1280 flash báo lỗi
    By dungsm in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 19-08-2013, 17:44
  2. xin giúp 1280 flash báo lỗi
    By lethanhtam92 in forum DCT4 - WD2
    Bài viết cuối: 21-05-2013, 16:58
  3. 1280 flash báo nhờ ae xem hộ
    By nguyendong_mobi in forum DCT4 - WD2
    Bài viết cuối: 27-08-2011, 10:18
  4. cần giúp flash 1280 bằng mx-key
    By vietlinh in forum DCT4 - WD2
    Bài viết cuối: 25-07-2011, 18:57
  5. 1280 anh em nào flash chưa
    By BUIVANCHUNG in forum DCT4 - WD2
    Bài viết cuối: 31-03-2011, 14:24
