Kết quả 1 tới 10 của 13
    Thành viên tích cực daochikien's Avatar
    Mar 2012
    hai duong
    Mặc định X2-01 cần ae giúp
    em có con X2-01 rơi đất chết nguồn , bây giờ chạy bằng usb thì em nó báo thế này , bác nào biết giúp hộ em với
    Number of Image Files: 3
    Processing Image File :
    rm709__08.70.mcusw
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 504
    Entry Point: 0x01F2
    Page Format : -1
    MAX PAGE : 0x0000E000
    rm709__08.70.ppm_v
    CMT Type : BB5
    Number of Blocks : 125
    Entry Point: 0x0113
    Page Format : -1
    rm709__08.70.image_v_059C2X8
    CMT Type : BB5
    Number of Blocks : 527
    Entry Point: 0x0147
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    Number of Sub Blocks 6 (0x06)
    1 SYSTEM_ASIC_ID 01
    Block Length : 17 (11)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000000
    ID DWORD 1 : 00000000
    ID DWORD 2 : 22000509
    ID DWORD 3 : 200C0000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00005361
    3 PUBLIC_ID 12
    Block Length : 21 (15)
    ID DWORD 1 : 0023119D
    ID DWORD 2 : F359AB42
    ID DWORD 3 : 08323E38
    ID DWORD 4 : ECAEC397
    4 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    5 ROOT_KEY_HASH 14
    Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
    6 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : DE56D582
    CRC 1 : BDDE7A3A
    CMT Secondary Loader: C:\ATF_NEW_DRIVERS\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_u sb2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0020 ->
    Device ID : 0030 -> Type not in database
    Revision ID : 0131
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0010 ->
    Device ID : 0011 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Revision ID : 0131
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data :
    Flash Descriptor
    Device ID : 0030
    Revision ID : 0000
    Size : 08000000 (128 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\ATF_NEW_DRIVERS\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_X SR16_usbalg.fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    IMEI: 357410048967608
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\ATF_NEW_DRIVERS\AdvanceBox Turbo Flasher\Nokia\Backup\357410048967608\3574100489676 08_21745.rpl
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    37955B6FC432998EF0DB240E332228384D19ED09
    ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-709\
    ImageFilename: rm709__08.70.mcusw
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00010000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 00020000
    Partition 2
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 02A00000
    Partition 3
    Start Address : 07540000
    Partition 4
    Start Address : 07B40000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000025E0000000000080000000102A0000004B400 000000000A0000000107540000006000000000000B00000001 07B40000001800000D
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0x90 (144)
    ERASE Blocks : 0x03 (3)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x2B (43)
    Device Index : 0x00
    0 : 00000000-0001FFFF
    1 : 00020000-000203FF
    2 : 00060000-012FFFFF
    3 : 01300000-01DFFFFF
    4 : 02600000-029FFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x02000000
    Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B0003000002000000 0203FF120B00030000060000012FFFFF120B00030001300000 01DFFFFF120B00030002600000029FFFFF11
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
    Successfully Erased...
    Total blocks to write : 504
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : MCUSW
    >> CMT Rootkey Hash CERT : MCUSW1
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : ISA+DYNSW
    ImageFilename: rm709__08.70.ppm_v
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    ERASE Blocks : 0x01 (1)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01E00000-025FFFFF
    ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E
    Total blocks to write : 125
    ImageFilename: rm709__08.70.image_v_059C2X8
    StartErase_DCT5...
    BlockLength : 0x3F (63)
    ERASE Blocks : 0x02 (2)
    Device Index : 0x00
    0 : 02A00000-0753FFFF
    Device Index : 0x00
    Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5001120B00030002A000000753FFFFE4
    FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
    Total blocks to write : 527
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    Status_BB5 STATUS_REQUEST_BB5..
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000004
    Additional Bad : 00000004
    Correctable ECC : 00000000
    FlashInfo.RestartMode : 2
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:11
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    WARNING: Phone is not in the Required Mode...
    Disconnect the Phone and Power it Up Manually.
    Quân đến thì tướng đánh _ Nước mạnh thì đắp đê...!
    Feb 2008
    lâm đồng
    nạp phonenix thử bạn
    D/C: LÂM HÀ_SUCCECSS_
    AGRIBANK-NGUYỄN NGỌC PHONG
    T/K ;5404205189065
  3. ( phongchinhphuc_pro™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    daochikien (03-06-2012)
    Thành viên kỳ cựu newnice's Avatar
    Mar 2012
    hải dương
    bật nó có lên ko . lên nhớ là phải dùng bằng pin đấy anh kiên ak!!!
    Đời___Là__Bể___Khổ
  5. ( newnice ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Mar 2012
    hai duong
    nạp bằng phonenix cũng không được
    Mar 2012
    hai duong
    em bật nguồn nó vẫn rung và lên nguồn nhưng màn hình sáng lên một cái là tắt luôn
  8. #6
    Mar 2012
    hai duong
    em nghĩ đây là phần mềm . bác nào biết bảo em với
  9. #7
    Moderator Thuyết Vũ's Avatar
    Gia lai
    đóng lại con CPU cho nó rồi chạy tiếp cái dòng x2-01, c3 hay bị vậy lám nhiều khi đóng xong sài một thời gian lại bị lại ah !
    Iphone Shop Thu Vân-sửa chữa apple Chuyên Nghiệp
    507 Nguyễn Huệ Núi Sập Thoại Sơn An Giang.YM: phong_vugl mobile: 0974444438
    Tài Khoản Vietcombank Gia Lai chủ tài khoản : Vũ Tiến Thuyết 0291002263263
  10. ( Thuyết Vũ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #8
    Mar 2012
    hai duong
    nếu làm phần mềm không được thì đành phải làm em cpu thôi . sợ khò vào là em ấy ngủ luôn ah . huhu !
  12. #9
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    dóngh lại con nguồn coi đã bạn . tiếp láy phonix ra quất . . xem nó báo j tiếp
    yahoo: viethuy_mobi
  13. ( viethuy_mobi ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  14. #10
    Thành viên chính thức Ashaung's Avatar
    May 2012
    Bến Xe Miền Đông
    Trích Được post bởi daochikien Xem bài viết
    Cơ hội không cao đâu, khò là nó chít chắc. Mua sẵn 2,3 con để thay thế đi bạn. Hì hì
    ashaungvan@gmail.com , [/COLOR] 0906815514
