    Thành viên mới tranhoacp's Avatar
    Nov 2010
    Than Q.Ninh
    Mặc định NOKIA 5250 cần giúp
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C083BBC3
    Using device: HTI, FW ver: 00.50, SN: 000075BE
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 1EF000176DAC0052D5F008676B16739BB1430E48
    ASIC MODE ID: 00
    ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
    ROM ID: 4B9B75103E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
    CMT PAPUBKEYS HASH: CA158EAEE7D8D7A5B2E4907CB6BD0A9C2794D992
    Processing MCU file: RM-684_30.0.002_prd.core.C00
    [BB5,XSR 1.6] size: 88.14 MB
    Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning ...OK
    Erase size: 165.19 MB
    CMT FLASH,MuxOneNAND area [00040000-00082FFF]
    CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
    CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
    CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
    CMT FLASH,MuxOneNAND area [00D60000-0A55FFFF]
    Formating partition ...
    Prog.status for Asic CMT ...
    NAND:Status reported bad blocks
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: CA158EAE [RAP Certificate v1 269] sent
    CMT SOS*UPDAPP block sent
    CMT SOS*ENO block sent
    CMT SOS*DSP0 block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    NAND: OK
    Programming completed in 3 min 58.187 s
    Processing PPM file: RM-684_30.0.002_prd.rofs2.V20
    [BB5,XSR 1.6] size: 24.25 MB
    Erase size: 42.75 MB
    CMT FLASH,MuxOneNAND area [069A0000-0945FFFF]
    NAND: OK
    CMT SOS+ROFS2 block sent
    NAND: OK
    Programming completed in 1 min 9.266 s
    Processing PPM file: RM-684_30.0.002_C01_prd.rofs3.fpsx
    [BB5,XSR 1.6] size: 3.46 MB
    Erase size: 17 MB
    CMT FLASH,MuxOneNAND area [09460000-0A55FFFF]
    NAND: OK
    CMT SOS+ROFS3 block sent
    NAND: OK
    Programming completed in 9.938 s
    Processing CNT file: RM684_30.0.002_000_000_U001.uda.fpsx
    [BB5,XSR 1.6] size: 16.96 MB
    Erase size: 79.12 MB
    CMT FLASH,MuxOneNAND area [0A560000-0F47FFFF]
    NAND: OK
    NAND: OK
    Programming completed in 49.328 s
    Total time for flashing process(boot+erase+write) was 6 min 17.797 s
    em nó chạy đến đây rồi thôi không chạy nữa
    V.I.P ĐƠ_NGUYỄN's Avatar
    bạn mang qua phonix chạy bằng usb xem sao
    Thành viên tích cực ATmobile_qn's Avatar
    Aug 2011
    Tình trạng máy sao bạn. Nạp ver cao nhất xem sao
    Yahoo:thanhtruyenmobile ĐT: 0989 413 413
    Trích Được post bởi ATmobile_qn Xem bài viết
    nó chạy đến đó rồi thôi vậy thì có chạy ver cao nhất cũng vậy thôi chỉ có có chuyển box khác hoặc chuyển qua phonenix múc cái chắc em nó sẽ tĩnh thoi!
    Thành viên kỳ cựu huphuc_mobile209's Avatar
    nạp lai USB bang hộp ATF thử đi bạn
    Feb 2008
    lâm đồng
    Nạp usb đi you
    D/C: LÂM HÀ_SUCCECSS_
    AGRIBANK-NGUYỄN NGỌC PHONG
    T/K ;5404205189065
  1. nokia 5250 sạc không đầy pin
    By ttrantrimobile in forum BB5
    Bài viết cuối: 28-04-2014, 11:21
  2. nhờ ae chỉ cách chọn file nokia 5250
    By huuphucmobile2012 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 16-05-2013, 12:12
  3. Trả lời: 4
    Bài viết cuối: 22-02-2013, 13:32
  4. Cần xin Font Tiếng viêt cho NOKIA 5250
    By pakchanghy in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 20-08-2012, 19:33
  5. xin giúp em cach Flas nokia 5250 băng ATF
    By emnhotoinghiep in forum BB5
    Bài viết cuối: 02-01-2012, 15:54
