Kết quả 1 tới 10 của 11
    Thành viên mới kebenle2010's Avatar
    Aug 2010
    Mặc định 1280 mât loa - chuông - rung
    như tiêu đề.mình đo trở thì giật lên cái rùi hạ xuống từ từ.đo tiếp thì không có.tháo ic chuông ra câu cũng không được,đóng U hơn 4 lần rùi vẫn thế.Flash lại thì nó báo
    Error reading checksum!
    log mình vừa Flash đây.anh em xem rui giúp mình với.
    thanks all !
    Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-647_90927C011B64881E_IMEI.back"
    MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0871603
    Using device: HTI, FW ver: 00.50, SN: 01007856
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version: Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
    CFI information:
    Flash settings: 0/1, size: 0x00800000
    2 Block regions:
    127 x 0x00010000 = 0x007F0000
    8 x 0x00002000 = 0x00010000
    EBL ready !
    Processing file: rm647_006.200
    Downloading item CODE:hw_b2_rm647_r06.200.fls, num block: 3, size: 3.99 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 43.937 s
    Erasing area 0x00C60000-0x00E4D5BE ...OK
    Programming completed in 41.172 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.171 s
    Processing file: rm647_006.20mr
    Downloading item CUST:hw_b2_rm647_006.20mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 20.766 s
    Checksum mismatch: Phone calculated 0x0033, software calculated 0xB874
    Processing file: rm6470_nai06.20mr
    Downloading item CUST:hw_b2_rm6470_nai06.20mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 5.688 s
    Checksum mismatch: Phone calculated 0x00F0, software calculated 0xD819
    Total time for flashing process(boot+erase+write) was 3 min 11.781 s
    Phone type: RM-647
    SW version: V 06.20 01-12-10 RM-647 (c) Nokia
    Imei plain: 35627304220480-3
    Product code: 0593211
    Cellular system: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: MR
    Language Pack:
    English,Hindi,Bengali
    Imei net: 35627304220480
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000030002
    Aug 2010
    cắm tai nghe vô cũng im re. anh em giúp mình với
    Thành viên tích cực sang_apple's Avatar
    Feb 2012
    F,3 Q4 ,Hồ Chí Minh
    sao ko nghe chú thớt thay cái chuông mới , cái này nó tích hợp 3 cái chung 1 và đi thẳng vào CPU nha bạn , nếu đã đóng cpu rồi mà ko dc thì thay mới xem sao
    tham khảo thêm nha bạn
    Luôn lắng nghe và học hỏi....
    Aug 2010
    cũng đã thay chuông khác rùi vẫn không ăn thua,còn phuơng án khác không bạn
    Thành viên tích cực khangdl84's Avatar
    Nov 2011
    mất cả loa ngoài lẫn trong hạ bạn. bạn khôi phục cài đặc gốc lại cái thử chưa. không được nửa thay cặp luôn
    Aug 2010
    mình flash lại rùi,cặp này mình lại không có,chẳng biết làm sao
    Thành viên tích cực TÍNH-NGHI_MOBILE's Avatar
    Feb 2011
    tui cũng bị một cây.bệnh này nó zô con xgoll rồi.thay cặp hoặc trã tùy bạn chọn
    Thành viên chính thức bamien_mobile's Avatar
    Nov 2010
    làm gì trã do tông tro co không nêu co go cpu flasl làm chân lai ok
    Thành viên tích cực thuy1986's Avatar
    làm lại chân x_gold coi sao ? x_gold con này đóng lại thoái mái nhưng che chắn flash lại không nó chết nhanh hơn x_gold
    Thành viên chính thức huynhphongmobile1's Avatar
    Aug 2011
    k cần đụng đến u đâu.....cạo mạch câu theo hình ok 100%...đã test.....hình hơi khó koi chịu khó ngâm cứu chút ha........of bạn j cho mình wen tên rùi......
  1. E63 không rung + chuông
    By giaitri85 in forum BB5
    Bài viết cuối: 04-12-2012, 16:51
  2. Trả lời: 10
    Bài viết cuối: 31-08-2012, 18:54
  3. c1- 01 rớt nước mất chuông loa rung
    By vutrieuca in forum DCT4 - WD2
    Bài viết cuối: 27-08-2012, 16:26
  4. 1661 mất chuôn và rung
    By nguyenvanson418 in forum DCT4 - WD2
    Bài viết cuối: 12-09-2010, 23:27
  5. E 715 không chuông +rung help
    By haidang1981_vn in forum Agere System
    Bài viết cuối: 29-03-2008, 09:08
