em nhân của khách con X3-02 khách bảo là lỗi phần mềm , em kẹp nguồn thì no cu lên trắng màn chơp chơpp vài cái rồi tắt , em bỏ vào MX key chay no báo như nay xin giúp thank.MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08598C8
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 000118A7
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Processing MCU file: rm639__07.16.mcusw
[BB5,XSR 1.6] size: 30.62 MB
Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 15A00215ABA60344DE1C1FF067D064B1213FCEE1
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 8789ABC
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35376404800321_CE RT.rpl).
CMT PAPUBKEYS HASH: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 45.06 MB
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
CMT FLASH,MuxOneNAND area [000A0000-0041FFFF]
CMT FLASH,MuxOneNAND area [00420000-0069FFFF]
CMT FLASH,MuxOneNAND area [006A0000-006DFFFF]
CMT FLASH,MuxOneNAND area [006E0000-0123FFFF]
CMT FLASH,MuxOneNAND area [02060000-020BFFFF]
CMT FLASH,MuxOneNAND area [02CC0000-0333FFFF]
CMT FLASH,MuxOneNAND area [07540000-07B3FFFF]
CMT FLASH,MuxOneNAND area [01240000-0205FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 23B57C26 [RAP Certificate v1 260] sent
CMT RAP3NAND block sent
CMT UPDAPP block sent
CMT LDSP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 6.578 s
Processing PPM file: rm639__07.16.ppm_v
[BB5,XSR 1.6] size: 8.66 MB
Erase size: 12 MB
CMT FLASH,MuxOneNAND area [020C0000-02CBFFFF]
Programming completed in 1.734 s
Processing CNT file: rm639__07.16.image_v_0598287_009
[BB5,XSR 1.6] size: 35.09 MB
Erase size: 66.06 MB
CMT FLASH,MuxOneNAND area [03340000-0753FFFF]
Programming completed in 7.844 s
Total time for flashing process(boot+erase+write) was 28.953 s
Warning: Phone did not reboot to normal mode.
			 X3-02 chạy phần mềm không được xin các huynh chỉ giúp thank.
