cây N81 8g của em mở nguồn lên tím màn hình khoảng 1 phút rồi sụp nguồn
đây là log mx box của nó
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0813E4E
Using device: HTI, FW ver: 00.50, SN: 00010A88
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 151002188E72005272F7F8B7D4C7DA49690921A6
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.2.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0221 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.2.0 revision: 2.0 size: 0x8B45D
CMT PAPUBKEYS HASH: E70C21157D5AB5AF61AAD376910751FB06D6E9FD
Processing MCU file: RM179_21.0.010_prd.C00
[BB5,XSR 1.5] size: 46.91 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101011105, 400C192101011105, 4003192101021103, 400C192101021103, 4003192101021105, 400C192101021105, 4003192101031103, 400C192101031103, 4003192101031105, 400C192101031105
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 92.37 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-0087FFFF]
CMT FLASH,MuxOneNAND area [00B80000-05F7FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: E70C2115 [RAP Certificate 45 V1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS*CORE block sent
CMT SOS+ROFS block sent
NAND: OK
Programming completed in 2 min 8.234 s
Processing PPM file: RM179_21.0.010_prd_0201.V02
[BB5,XSR 1.5] size: 32.01 MB
Erase size: 40.31 MB
CMT FLASH,MuxOneNAND area [03730000-05F7FFFF]
NAND: OK
CMT SOS+ROFX block sent
NAND: OK
Programming completed in 1 min 31.281 s
Processing CNT file: RM179_21.0.010_002_erase_uda.fpsx
[BB5,XSR 1.5] size: 204 Bytes
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103
Erase size: 26.37 MB
CMT FLASH,MuxOneNAND area [05F80000-079DFFFF]
NAND: OK
NAND: OK
Programming completed in 0.094 s
Processing MMC file: RM179_erase_E.fpsx
[BB5,XSR 1.5] size: 8.05 MB
Erase skipped.
Error while programming [00] at 0x00000000, Result: 0000
Warning: programming MMC failed, please check if MicroSD exist !
Programming completed in 20.344 s
ERROR: Packet Error(0xAA), code 0xA4000002
Total time for flashing process(boot+erase+write) was 4 min 13.515 s
mong mấy cao thủ giúp dùm
