em nhận n97 mini mở nguồn chỉ rung một cái rồi sụp luôn,em chạy lại ver cao nhất rồi lúc chạy nó hiển thị loca mode nếu chạy nó báo vậy là thông số máy có nguồn nhưng khi lấy ra và mở nguồn thì cũng chỉ rung thôi có anh nào gặp qua giúp em với
lock em chạy bằng mx-box
Flasher Interface (WinUSB) 3], SN: C085A0B8
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00008AED
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
Processing MCU file: RM-505_22.0.110_prd.core.C00
[BB5,XSR 1.5] size: 106.34 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 15200212E1DA01586F6598726CA8538EE1C84EE1
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 167.44 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0AB9FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: DAEF2C39 [RAP Certificate 166 v.1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 36.844 s
Processing PPM file: RM-505_22.0.110_prd.rofs2.V03
[BB5,XSR 1.5] size: 23.94 MB
Erase size: 35 MB
CMT FLASH,MuxOneNAND area [079A0000-09C9FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 22.266 s
Processing PPM file: RM-505_22.0.110.220.05.rofs3.fpsx
[BB5,XSR 1.5] size: 4.82 MB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [09CA0000-0AB9FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 4.532 s
Processing CNT file: RM505_APE_ONLY_ENO_09w23_v0.072.fpsx
[BB5,XSR 1.5] size: 2.75 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT SOS*ENO block sent
Programming completed in 2.579 s
Processing CNT file: RM505_22.0.110_004_U220.uda.fpsx
[BB5,XSR 1.5] size: 9.74 MB
Erase size: 75.50 MB
CMT FLASH,MuxOneNAND area [0ABA0000-0F71FFFF]
Programming completed in 9.875 s
Total time for flashing process(boot+erase+write) was 2 min 23.531 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdc\Nokia N97 USB Phonet, PORT_ID: 82B2589
Verifying communication to device OK.
Phone type: RM-505 (Nokia N97)
SW version: V ICPR72_09w44.18 28-05-10 RM-505 (c) Nokia
ApeCoreSw: v 22.0.110
Imei plain: 35422503308815-9
Product code: 0576122
Battery voltage: 3762 mV, current: 270 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354225033088159
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
