    Thành viên mới phanchaukhoa's Avatar
    Apr 2010
    Mặc định Mấy Anh xem giúp em cái log 2700c này bị gì
    Máy mới đầu chớp tắt màng hình, rồi tắt mấy, em đã khò nhẹ con 2 tầng, khò xong không lên nguồn luôn, em chạy lại bằng Phoenix chế độ Dead phone USB flashing, nhờ mấy anh xem hộ thử bị gì cảm ơn mấy anh
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 14592 bytes
    Secondary boot loaded
    Loading update server code: 308032 bytes
    Update server loaded
    Asic CMT: Verifying communication to device...
    Asic CMT: Start programming 37894 KB...
    Asic CMT: Erasing rm561__09.98.mcusw
    Asic CMT: Erasing area 1...
    Asic CMT: Erasing area 2...
    Asic CMT: Erasing area 3...
    Asic CMT: Erasing area 4...
    Asic CMT: Erasing area 5...
    Asic CMT: Erasing area 6...
    Asic CMT: Erasing rm561__09.98.ppm_t
    Asic CMT: Erasing rm561__09.98.image_ctv_nz_gray
    Asic CMT: Programming rm561__09.98.mcusw
    Asic CMT: Programming 0%
    Asic CMT: Programming 2%
    Asic CMT: Programming 4%
    Asic CMT: Programming 6%
    Asic CMT: Programming 8%
    Asic CMT: Programming 10%
    Asic CMT: Programming 12%
    Asic CMT: Programming 14%
    Asic CMT: Programming 16%
    Asic CMT: Programming 18%
    Asic CMT: Programming 20%
    Asic CMT: Programming 22%
    Asic CMT: Programming 24%
    Asic CMT: Programming 26%
    Asic CMT: Programming 28%
    Asic CMT: Programming 30%
    Asic CMT: Programming 32%
    Asic CMT: Programming 34%
    Asic CMT: Programming 36%
    Asic CMT: Programming 38%
    Asic CMT: Programming 40%
    Asic CMT: Programming 42%
    Asic CMT: Programming 44%
    Asic CMT: Programming 46%
    Asic CMT: Programming 48%
    Asic CMT: Programming 50%
    Asic CMT: Programming 52%
    Asic CMT: Programming rm561__09.98.ppm_t
    Asic CMT: Programming 54%
    Asic CMT: Programming 56%
    Asic CMT: Programming 58%
    Asic CMT: Programming 60%
    Asic CMT: Programming 62%
    Asic CMT: Programming 64%
    Asic CMT: Programming 66%
    Asic CMT: Programming 68%
    Asic CMT: Programming 70%
    Asic CMT: Programming rm561__09.98.image_ctv_nz_gray
    Asic CMT: Programming 72%
    Asic CMT: Programming 74%
    Asic CMT: Programming 76%
    Asic CMT: Programming 78%
    Asic CMT: Programming 80%
    Asic CMT: Programming 82%
    Asic CMT: Programming 84%
    Asic CMT: Programming 86%
    Asic CMT: Programming 88%
    Asic CMT: Programming 90%
    Asic CMT: Programming 92%
    Asic CMT: Programming 94%
    Asic CMT: Programming 96%
    Asic CMT: Programming 98%
    Asic CMT: Programming 100%
    Waiting for communication response: 25
    Waiting for communication response: 24
    Waiting for communication response: 23
    Waiting for communication response: 22
    Waiting for communication response: 21
    Waiting for communication response: 20
    Waiting for communication response: 19
    Waiting for communication response: 18
    Waiting for communication response: 17
    Waiting for communication response: 16
    Waiting for communication response: 15
    Waiting for communication response: 14
    Waiting for communication response: 13
    Waiting for communication response: 12
    Waiting for communication response: 11
    Waiting for communication response: 10
    Waiting for communication response: 9
    Waiting for communication response: 8
    Waiting for communication response: 7
    Waiting for communication response: 6
    Waiting for communication response: 5
    Waiting for communication response: 4
    Waiting for communication response: 3
    Error 0x8401F121 communicating to phone. Unable to verify comm.
    Warning: Unable to communicate to product after flashing
    Starting to recover the phone
    Recovering phone
    Initializing
    ERROR: Unable to detect device 0x8401F145. Check USB connection
    ERROR: Product recovery failed
    Unable to set the phone to flash mode. Unable to flash.
    Recovering phone
    Initializing
    Recovering phone
    Initializing
    All operations completed
    Product flashing aborted
    Apr 2010
    lỗi rồi mình cũng đang chạy con nè lấy hwk hoặc mx box mà flash đi anh bạn ơi không hết thì xem lại cập nhé anh bạn
    Apr 2010
    cái log này em chạy bên JAF anh nào xem hộ dùm em
    JAF version 1.98.65 beta1
    Detected PKEY: 9000A017
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 7.1.69.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-561\
    Checking path: \Products\RM-561\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_t
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.image_ctv_nz_gray
    Languages in ppm: English,Philipines,Bangladesh,Australia,Indonesia, India,Vietnam,New Zealand
    Backing up CRT...
    Detected P-KEY: 9000A017
    Init usb communication...
    Failed to backup CRT...
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 06.02.002
    Elf2flash 09.07.000
    CMT RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step3...
    Sending RAW Loader...
    ...................Loader Sent!
    Stage 2 starting.......................................... .....................................Loader Sent!
    Stage 3 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 8000
    Selecting CMT flash...
    Result: 0000
    Phone is in flash mode...
    CMT blocks: 2394, APE blocks: 0
    Erasing cmt...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw...
    Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
    Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
    Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
    Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
    Erasing cmt zone 00140000 - 0137FFFF ... Erase result: 0000
    Erasing cmt zone 01380000 - 0151FFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_t...
    Erasing cmt zone 01520000 - 01DBFFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.image_ctv_nz_gray...
    Erasing cmt zone 01DC0000 - 0215FFFF ... Erase result: 0000
    Erasing cmt zone 02160000 - 03FBFFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    cmt->PAPUB keys already sent...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Rebooting...
    Finishing CMT session...
    Restarting CMT...
    Pooling phone...
    Phone not found...
    Done!
    Thành viên chính thức limienpack's Avatar
    Lào Cai
    chớp tắt mà bạn đã động đến cặp rồi.đáng lẽ ra bạn chạy phần mềm chước thì tốt hơn.lỗi chớp tắt chặy phần mềm là được mà bạn
    XUÂNBẮC MOBILE
    D/C:TỔ 13 BM/LÀO CAI ..DT:0989589500. YH:limienpack_kute
    V.I.P ThanhHai_GSM's Avatar
    bệnh chóp tắt 2700c 90% lỗi cặp chủ yếu flash dòng samsung
    backup ful rpl và pm 120 thay flash nạp lại done
  1. xin giúp 2700c
    By manhdung81mobile in forum BB5
    Bài viết cuối: 24-06-2012, 10:56
  2. 2700c cần anh em giúp
    By thanhphuek in forum BB5
    Bài viết cuối: 04-09-2011, 00:25
  3. 2700c xin giúp
    By hanayuky18 in forum BB5
    Bài viết cuối: 03-09-2011, 15:40
  4. Trả lời: 15
    Bài viết cuối: 01-06-2011, 12:30
  5. 2700c cần giúp
    By anhquoc in forum BB5
    Bài viết cuối: 24-08-2010, 08:34
