tình hình em nhận con 6100 contacservic , mình check thì thì như này, nhờ ae giúp
thanks all
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D93
Using device: HTI, FW ver: 00.50, SN: 0000B3E9
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
UEM ID: 0000B6A0:2984DA60
ASIC type: 2
UEM Imei: 35339600033440
Flash Imei: 35339600033440
MasterCode: 4404046443
RPL saved to "C:\mobileEx\3.5\data\backup\35339600033440_BACK.r pl"
Phone type: NPL-2 (Nokia 6100)
SW version: V 05.51 27-02-04 NPL-2 (c) Nokia.
Imei plain: 35339600033440-4
Imei OTP: 35339600033440
Product code: 0510845
Cellular system: GSM
ASIC ID: 0x1120, type: 2
Ppm Id: V
Language Pack:
English,Chinese S,Chinese T,Vietnamese
Master code: 4404046443
Security code: 12345
Imei net: 35339600033440
Version: SIMLOCKLIB VERSION 2.26
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
			 xem giúp log 6100 contacservic
