Kết quả 1 tới 10 của 18
    Thành viên tích cực 99999's Avatar
    Dec 2011
    Mặc định unlock 5300-b rm-147
    unlock 5300-b rm-147 , em có mxbox , jaf
    con này có phải là phần cứng ko ae,
    xin ae chỉ giúp , thanks
    aitun : Do1234567 - do_gsm@yahoo.com.vn ; phattaigsm@yahoo.com - Do1234567
    sicado80@gmail.com.vn - pass: oooooooo
    Thành viên mới phachinhmobile's Avatar
    Nov 2010
    bỏ vào mxkey unlook xem sao bạn
    Thành viên chính thức toantkx92's Avatar
    Jun 2011
    cho vào mxbox bạn pm lại unloock ok lựom lua nha bạn
    Dec 2011
    flash lại , unlock , thì log đẹp nhưng ko có sóng
    Version from phone: 05.51
    Version from file: 07.20
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D93
    Using device: HTI, FW ver: 00.50, SN: 0000B3E9
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35643301397150_BA CK.rpl).
    Processing MCU file: rm146__07.20.mcusw
    [BB5,BB5 ALGORITHM] size: 14.56 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 1450010357C36D5644AB187D757F395D9F51915B
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00020000-0007FFFF]
    CMT FLASH,NOR area [00080000-000DFFFF]
    CMT FLASH,NOR area [00100000-001FFFFF]
    CMT FLASH,NOR area [00200000-0031FFFF]
    CMT FLASH,NOR area [00320000-0105FFFF]
    CMT FLASH,NOR area [01060000-01067FFF]
    CMT FLASH,NOR area [01068000-0107FFFF]
    erased in 42.828 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 7C1A1F5C [Rap Certificate 30 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    NOR: OK
    Programming completed in 1 min 16.781 s
    Processing PPM file: rm146__07.20.ppm_v
    [BB5,BB5 ALGORITHM] size: 5.25 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 5.50 MB
    CMT FLASH,NOR area [01080000-015FFFFF]
    erased in 10.968 s
    NOR: OK
    NOR: OK
    Programming completed in 29.719 s
    Processing CNT file: rm146__07.20.image_v_black
    [BB5,BB5 ALGORITHM] page size: 64 K size: 5.44 MB
    NOR page size in the phone is 128 K.
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 9.87 MB
    CMT FLASH,NOR area [01600000-01FDFFFF]
    erased in 28.079 s
    NOR: OK
    Converting UCP blocks to 128 K.
    NOR: OK
    Programming completed in 29.609 s
    Total time for flashing process(boot+erase+write) was 4 min 12.375 s
    Phone type: RM-146 (Nokia 5300)
    SW version: V 07.20 23-10-08 RM-146 (c) Nokia.
    Imei plain: 35643301397150-5
    Product code: 0546896
    Battery voltage: 4286 mV, current: 16 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 356433013971505
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Dec 2011
    ae cho mình xin file rpl có HWC và CCC mình write cho nó ,links trên 4r bị die hết rồi
    Dec 2011
    mình chạy file rm-164 , write pm full bây giờ sóng rất yếu
    nhờ ae giúp
    Thành viên chính thức tridongthap75's Avatar
    Nov 2006
    Châu Đốc - An Giang
    Dùng HWK write 2 file này vào thử xem
    RM-146_CCCCmt.bin
    RM-146_HWCCmt.bin
  8. ( tridongthap75 ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    99999 (11-07-2012), vanbang134 (19-07-2012)
  9. #8
    Super Moderator namnhatrang's Avatar
    Jan 2007
    lấy JAF nạp cái file này vô : http://www.4shared.com/file/V2JXwceo...andChange.html
  10. ( namnhatrang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (11-07-2012)
  11. #9
    Dec 2011
    mxbox write được ko pro
  12. #10
    Jan 2007
    chưa thử , có mxkey thì backup imei lại rùi múc thử coi sao
  13. ( namnhatrang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (11-07-2012)
  1. help me 5300 unlock!
    By huynguyen245 in forum BB5
    Bài viết cuối: 29-10-2008, 00:35
  2. Cưu gấp unlock 5300!
    Bài viết cuối: 28-10-2008, 19:30
  3. unlock 5300 bị lỗi....
    By vinh2005 in forum AdvanceBB5 Box
    Bài viết cuối: 14-10-2008, 14:36
  4. Trả lời: 1
    Bài viết cuối: 01-08-2007, 13:01
  5. Unlock 5300 ?
    By haithong in forum BB5
    Bài viết cuối: 05-07-2007, 11:10
