Kết quả 1 tới 10 của 10
    Thành viên mới meocon81's Avatar
    Mặc định cao thủ xen dùm em cai lốc
    máy lúc đầu đòi mật khẩu bẻ khóa ko dc nên chạy pm nhưng lai bị contact service đã thay uem >>>cpu not ok
    đây là lốc của em nó
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085886D
    Using device: HTI, FW ver: 00.50, SN: 000074D6
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
    ASIC ID: 0x2292 [UPPCosto ver: 1.3]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
    UEM ID: 0054EDD4A3BDA66
    ASIC type: 11
    UEM Imei: 35152704667784
    Flash Imei: 35152704667784
    RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35152704667784_BA CK.rpl"
    Processing MCU file: rh105_05.910
    [DCT4,DCT4 ALGORITHM] size: 2.28 MB
    Supported Ids: 2292
    UEM ID: 0054EDD4:2984DA60
    Area [01000000-0100FFFF] erased in 0.547 s
    Area [01010000-013AFFFF] erased in 31.641 s
    Area [013B0000-013EFFFF] erased in 2.375 s
    Area [017C0000-017EFFFF] erased in 0.016 s
    Area [01FC0000-01FEFFFF] erased in 0.016 s
    Flash programming ...
    Programming completed in 19.625 s
    File processed in 1 min 1.625 s
    Processing CNT file: rh1050_nai5.91mr
    [DCT4,DCT4 ALGORITHM] size: 139.53 KB
    Supported Ids: 2292
    Area [01380000-013AFFFF] erased in 1.688 s
    Programming completed in 1.203 s
    Content extract fail, continue anyway ...
    File processed in 9 min 58.640 s
    Processing PPM file: rh105_05.91mr
    [DCT4,DCT4 ALGORITHM] size: 1.20 MB
    Supported Ids: 2292
    Area [01240000-0124FFFF] erased in 0.531 s
    Area [01250000-0137FFFF] erased in 10.704 s
    Programming completed in 10.485 s
    File processed in 29.141 s
    Total time for flashing process(boot+erase+write) was 11 min 29.406 s
    Moderator Apple179's Avatar
    Sep 2010
    đủa qua hộp khác chạy thủ con kg làm chân lại con flash...............
    DV sửa chữa iphone cho anh em
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    xóa flash nạp lại thử xem
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    chuyển box khác xóa + flash lại + writer pm _ unlook .
    vẫn ko dc thì che chân vpp( chân số 6 ) làm lại
    yahoo: viethuy_mobi
    Thành viên mới quangvu_mb's Avatar
    Máy Bác là máy gì vậy
    bình phước
    sac, mã bảo vệ rồi chay CT bị contac và sao duc đẽo chi vậy, xem lại có chạy lộn file ko orxem simlock còn ko. đả.
    Thành viên chính thức vanchuongmobile's Avatar
    Jun 2011
    Chưa gì đã cày tung lên rồi, có mx box sao không update sim luck trước. làm như vip vietthuy nếu not ok xem lại flast
    Trích Được post bởi quangvu_mb Xem bài viết
    làm như chú huy not ok làm lại com upp nha đá cho em no 1 phát cẩn thận upp rễ deas chỉ mã bảo vệ bị contac mà lại làm cứng sao bạn chạy song ko unloc là nó contac rùi tiện có mx sao ko updet cho nó cái sim lock
    Thành viên chính thức tridongthap75's Avatar
    Nov 2006
    Châu Đốc - An Giang
    Đây nè bạn
    @ chủ thớt : Sao lúc đầu làm mềm thì không tìm cách chạy lại trước cái ?
    V.I.P Lão_Đại's Avatar
    hải phòng
    Em này đồ lộ cộ quá
    - theo cái IMEI này (Flash Imei: 35152704667784) thì em nó là con _ Nokia 5030 Xpress
    - Tại sao chủ thớt lại chạy PPM file: rh105_05.91mr , Phải chăng lấy cả cặp 5030 đóng sang 1208 ?
  1. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  2. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  3. Anh em chỉ dùm hộp mt-box
    By trangvinh in forum MT-Box
    Trả lời: 27
    Bài viết cuối: 26-12-2012, 10:37
  4. mấy anh xem dùm em cái log N70 với
    By liencuongmobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 04-04-2010, 11:33
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
