Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 24
    Thành viên tích cực daochikien's Avatar
    Mar 2012
    hai duong
    Mặc định 2730 cần ae giúp
    ATF Software Version v8.90
    ATF Nitro FBUS Flash Started...
    Number of Image Files: 3
    Basic Phone Information
    WARNING: Simlock Backup Failed
    If this is a Dead Phone, just click YES
    to Continue with the Flash Procedure...
    Changing MODE : FLASH
    Booting Phone via FBUS...
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 3 Attempts
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01023000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 14000115
    ID DWORD 1 : 65810F56
    ID DWORD 2 : 11143FDB
    ID DWORD 3 : 3FAA41CA
    ID DWORD 4 : B267637D
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum 05
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0089 ->
    Device ID : 8982 -> NU48F512
    Extended/Fixed ID : 0000
    Revision ID : 8A31
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : 51
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
    Flash Descriptor
    Device ID : 8982
    Revision ID : 0000
    Size : 04000000 (64 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    SendAlgoCodeFile_DCT5 : Error
    Try TO UNPLUG RJ45 AND TRY AGAIN
    Failed to complete RPL backup..
    Processing Image File :
    C:\Program Files\Nokia\Phoenix\Products\RM-578\rm578__10.40.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 3250000 Hz
    Algorithm Sending Speed : 6500000 Hz
    Program Sending Speed : 6500000 Hz
    Message Reading Speed : 98000 Hz
    Number of Blocks : 1395
    Entry Point : 0x457E
    Page Format : 128K
    Maximum Page Size : 0x00004000
    SET BSI Load Done
    BootFlashMode_DCT5
    TIME STARTS HERE
    1 SYSTEM_ASIC_ID 01
    2 EM_ASIC_ID 02
    3 EM_ASIC_ID 02
    4 PUBLIC_ID 12
    5 ASIC_MODE_ID 13
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    7 ROM_ID 15
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum 05
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    Device Index : 00
    Revision ID : 8A31
    Block Length : 13
    Device Index : 00
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Checksum : 51
    SendAlgoCode_DCT5..
    Flash Descriptor
    Device ID : 8982
    Revision ID : 0000
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    Pabub KEY Request
    No PAPUBKeysHash Returned
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    VPP Enabled by Software
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x36 (54)
    ERASE Blocks : 0x01 (1)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x33 (51)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x00 NOR
    Device Index : 0x00
    0 : 00000000-000006BF
    1 : 000006C0-0001FFFF
    2 : 00040000-000BFFFF
    3 : 000C0000-0013FFFF
    4 : 00140000-0155FFFF
    5 : 01560000-0175FFFF
    Erase_SendEraseBlock_BB5_NOR
    Task in Progress... Please Wait...
    FAILED ERASING....
    Operations Failed....
    đây là log của em nó ae xem hộ em với là nó bị lỗi gì
    Quân đến thì tướng đánh _ Nước mạnh thì đắp đê...!
    Thành viên mới nguyenluanlk89's Avatar
    Jan 2009
    a phải nói thêm là máy bị như thế nào và a đả làm những ji thì mọi người mới dễ giúp a chứ
    Thành viên kỳ cựu KUNEK_GSM™'s Avatar
    Jun 2011
    THIẾU LÂM TỰ
    cho qua phonix chơi thử xem
    NGỌC NĂNG SERVICE LÂM HÀ-LÂM ĐỒNG
    CHUYÊN : unlock repair update Firmware tiếng việt ALL MOBILE
    Y/H nangngocdao09@yahoo.com
    SDT:0977+1+7+1+0+3+7
    TK AGRIBANK 5404205189059
    V.I.P BinhMinhGSM's Avatar
    Apr 2008
    Vĩnh Long->Đà Nẵng
    Lắc chân nhẹ con Flash rồi flash lại thử xem,chứ ATF mà còn k done thì phoenix chỉ có ngồi ngó.1 cái free,1 cái mấy chai mà sao qua mặt đc.nếu đc thì tụi ATF phá sản à
  5. ( BinhMinhGSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    daochikien (02-07-2012)
    Mar 2012
    hai duong
    máy của khách bị rơi xuống nước đã mang đi quán khác làm rồi , mang đến mình mở ra đã thấy mỡ ở khắp nơi rồi , mình chưa làm gì cả mới mang check thử , muốn hỏi ý kiến ae xem là nó bị làm sao để còn có phương án khắc phục
    V.I.P ThanhHai_GSM's Avatar
    Trích Được post bởi daochikien Xem bài viết
    có cặp thì thay cặp còn không đóng trả khách
  8. ( ThanhHai_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #7
    Mar 2012
    hai duong
    ngoài thay cặp ra không còn cách gì khác hả anh !
  10. #8
    Thành viên mới ngocmaimobile's Avatar
    Jun 2012
    may cua ban nhan cua khach ma co nguoi lam roi thi ban co the dong lai hoac lay cap khac dong sang neu khong dc thi {tuoc quan tich tra ve dia phuong} thoi gian do de uong nuoc che voi anh em cho mat !
  11. #9
    Mar 2012
    hai duong
    ok để en làm lại con flash rồi em báo lại các bác sau nha
  12. #10
    Thành viên tích cực cuongmobile4078's Avatar
    Jun 2012
    ha nội
    máy đã qua thợ mà lam không được đến tay minh thì cũng đành trả khách luôn thôi nát bét rồi bạn ah
    luôn luôn lắng nghe.luôn luôn chia sẻ
    yh:cuongmobile4078 DT:0433646344 DD:0974201988
  1. Trả lời: 15
    Bài viết cuối: 22-01-2014, 15:39
  2. 2730 mất đèn cần giúp
    By dangthanhtra in forum BB5
    Bài viết cuối: 23-02-2013, 17:50
  3. 2730 cần giúp.
    By trongnghiamobile in forum BB5
    Bài viết cuối: 09-02-2013, 22:49
  4. 2730 cần anh em giúp tay
    By canhduan in forum BB5
    Bài viết cuối: 24-02-2012, 09:14
  5. 2730 xin Giúp mất đèn
    By ducquanbluestar2000 in forum BB5
    Bài viết cuối: 09-11-2011, 09:47
