em có con x1-01 lắp sim 2 vào thì nó báo take invalid sim out...nhung lắp sang sim 1 thì vẫn dùng binh thường... bác nào gặp qua chỉ em với...thaks all
em đã chạy lại phần mềm
				 x1-01 báo  take invalid sim out
Đời___Là__Bể___Khổ
				bạn cho vào box chạy lại cho e nó cái xem thế nào, nếu nót ok thì quang cái log lên ae coi sao.
newnice (06-07-2012)
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Documents and Settings\03203522264\Desktop\X1-01 RM-713 v07.50 ppm_mr Full\rm713_007.500
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00000000~0x0001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 24576 bytes
Data Checksum: 55FD
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 4128768 bytes
Data Checksum: AA06
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 1697536 bytes
Data Checksum: C1B9
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Documents and Settings\03203522264\Desktop\X1-01 RM-713 v07.50 ppm_mr Full\rm713_007.50mr
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00100000~0x006120BE
Start Erasing...
Block Erase Done...
Data Size: 5316800 bytes
Data Checksum: 93CE
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Documents and Settings\03203522264\Desktop\X1-01 RM-713 v07.50 ppm_mr Full\rm7130_nai07.50mr
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00E60000~0x00F0E53E
Start Erasing...
Block Erase Done...
Data Size: 714048 bytes
Data Checksum: 111B
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:04:21
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 07.50 29-11-11 RM-713 (c) Nokia
IMEI: 359321042014842
Product Serial Number: 62A10E7AH
Product Code : 059G464
Module Code : 0204727
Basic Production Code: 059L8X6
PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MR
ADSP Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nmr
MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia
HW Version : 1000
UEM Version : 1328
UPP Version : 8850
LCD Version : TPO:BARACOAv82 HX5081
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000030002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : PASSED
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Đời___Là__Bể___Khổ
				log của nó đấy ... em chạy bằng atf
Đời___Là__Bể___Khổ
				hinh nho qua anh oi]
Đời___Là__Bể___Khổ
				Bạn thay con ic sim 2 trước kok được thì làm con màu đen theo hình
D/C: LÂM HÀ_SUCCECSS_
AGRIBANK-NGUYỄN NGỌC PHONG
T/K ;5404205189065
				uk các bác còn cách nào lữa ko giúp em với
Đời___Là__Bể___Khổ
				bạn làm gì rồi hay hỏi để đó thuib
T/K ;5404205189065
				em chạy phần mềm ui
em dang có 1 con
nhưng ko pít làm từ dâu
Đời___Là__Bể___Khổ
