Kết quả 1 tới 10 của 14
    Thành viên kỳ cựu newnice's Avatar
    Mar 2012
    hải dương
    Mặc định can các bác xem hộ cái log ....2700
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 3 Attempts
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01033000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 1F100215
    ID DWORD 1 : C4B67D56
    ID DWORD 2 : BD2A0693
    ID DWORD 3 : 555AB3EF
    ID DWORD 4 : A25A3C48
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum C1
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0089 ->
    Device ID : 8982 -> NU48F512
    Extended/Fixed ID : 0000
    Revision ID : 8A31
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : 51
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
    Flash Descriptor
    Device ID : 8982
    Revision ID : 0000
    Size : 04000000 (64 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    OLD Protocol Detected... Using Turbo Mode...
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    3EA22A1DDA660002E56108DB5072A10F8709443F
    Scanning Simlock Applet Type...
    OK
    PA_SL3 Applet detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    Basic Phone Information
    MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia
    IMEI Plain : 354192031278143
    IMEI Spare : A354192031278140
    IMEI SV : 33541920312781455F
    Phone Model: Nokia 2700 classic
    Category : Classic Phone
    Phone Type : RM-561
    Extended Phone Information
    Product Serial Number: 0
    Long Production SN : 0
    PPM SW Version : V 09.98 06-09-10 RM-561 (c) Nokia V
    BT MCM Version : 2222-302
    MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia
    RFIC Version : 06540601
    DSP Version : ICPR72_09w26
    LCD Version : SEIKO
    Content Pack Version : Content: v_black V 09.98 06-09-10 RM-561 (c) Nokia
    AHNE Version : 30
    RETU Version : 16
    TAHVO Version : 22
    Bluetooth ID : 00:250:C2:63:42
    CS Type : GSM850, GSM900, GSM1800, GSM1900
    Simlock Information
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    Dynamic Camera Configuration
    DCC ID : NIMMIIIIRRFF00000000
    DCC Ver: XXXXXX
    ERROR: DCC File Mismatched!
    Required DCC File: NIMMIIIIRRFF00000000
    Write the correct DCC to Fix the Problem
    Selected VPL File:
    RM561_0581057_09.98_032.vpl
    Variant Details : RM-561 SEAP_V_GRAY_STROKE_VIETNAM
    Software Version : 09.98
    Product Type : RM-561
    Product Code : 0581057
    Variant Version : 032
    thanh các bác nhìu
    Đời___Là__Bể___Khổ
    h tình trạng máy thế nào bạn cho qua hộp khác fash lại hay phonix xem
    Mar 2012
    hải dương
    tinh trang em nó ..cắm sạc báo ko hỗ trợ bộ sạc đã làm các kiểu ùi mà ko được
    Đời___Là__Bể___Khổ
    bình phước
    Trích Được post bởi newnice Xem bài viết
    Thay R2071= 47k not ok thay ic sạc 4 chân r2700 không hết nữa thay con R2300 kế chân pin cuối cùng là con tavo IC nguốn nhỏ. hết.
  5. ( phone_lucky ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tuanvan2012 (14-07-2012)
    Thành viên chính thức tinhdml's Avatar
    Dec 2010
    Đắk Nông
    Trích Được post bởi phone_lucky Xem bài viết
    Con nguồn nhỏ betty chứ không phải tahvo nha.tìm con tahvo trên 2700 có chít liền ak
    P&T mobile
    yahoo:minhphuc_mobileT:0965248678
  7. ( tinhdml ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    newnice (15-07-2012)
  8. #6
    Mar 2012
    hải dương
    làm mãi ko được em giả may khách ui cảm ơn các bác
    Đời___Là__Bể___Khổ
  9. #7
    Thành viên kỳ cựu dinhhieu444's Avatar
    ĐỒNG NAI
    bạn đã làm những gì ?r47k múc chưa bạn, cát diot chưa , lắc hoặc thay tavo chưa bạn.
  10. #8
    ĐỒNG NAI
  11. #9
    Mar 2012
    hải dương
    ko dk
    các bvacs ak
    Đời___Là__Bể___Khổ
  12. #10
    Thành viên tích cực TÍNH-NGHI_MOBILE's Avatar
    Feb 2011
    Máy bị lỏi camera nửa kìa
    lyvant@yahoo.com.vn 0934030540
  1. 2700 rơi nước mất toàn bộ đèn
    By Trường_Mobile in forum BB5
    Bài viết cuối: 20-05-2013, 10:52
  2. 2700 liệt phím
    By mainhancon in forum BB5
    Bài viết cuối: 06-02-2012, 13:30
  3. 2700 bệnh la
    By songgio in forum BB5
    Bài viết cuối: 11-12-2011, 16:23
  4. cặp 2700
    By linhsaker in forum BB5
    Trả lời: 24
    Bài viết cuối: 03-10-2011, 14:37
  5. 2700 ver 10.47.. hạ 10.45.. có ok
    By juyaku in forum BB5
    Bài viết cuối: 10-05-2011, 09:13
