máy không nhận sim,mình bỏ vào jaf chạy thì nó báo như thế này!rồi đứng yên không chạy được nữa!xin anh em xem giúp và cho hướng xử lý dùm! thank's!
JAF version 1.98.62
Detected PKEY: 90009B6C
Card life counter: 99.99%
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
USB Cable Driver version: 7.1.40.0
Changing mode...Done!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101012200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 1160020ABCEA5851669145DF4AD28135AE6C85F2
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 00020001 <=> SPANSION -> Type not in database
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk07v47
30-01-07
RM-180
(c) Nokia.
HW version: 5002
PCI version:
RFIC version: 150f160f
DSP version: rolf_espresso_05wk07v29p1
Retu version: 32
Tahvo version: 53
Production serial number: CJI295776
Product code: 0531541
Module code:
Basic production code: 0530940
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354533018905788
IMEI spare to net: 3A 45 35 03 81 09 75 08
IMEI SV to net: 33 45 35 03 81 09 75 08 F6
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
Setting local mode...
Reading product code...
Product Code: 0531541
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-180\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\rm180_50706401.c0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50706401.V12
Languages in ppm: English,Trad Chinise,Indian
Done!
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35453301890578_CRT_backup _1045147.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\354533018905788_CRT_backu p_1045147.pm
Done!
Backup LCK OK!
Reading SW version...05wk07v47
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
dịch câu này ra là :
Khối APE hiện diện trong tập tin flash nhưng không có APE mcu phát hiện trong điện thoại. Hủy bỏ!
cho em hỏi APE là gì vậy? và máy em bị gì?cần làm gì?còn gà quá!
			 nhờ anh em xem giúp cái log của n72!
