Version from phone: 07.30
Version from file: 07.30
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C08536CF
Using device: HTI, FW ver: 00.50, SN: 00003706
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012)
Reading RPL backup ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 30200110DB0D7F5603D83BF753BB70F0F3FA5B56
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
eBB5ProtocolType: OLD
Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Flash Imei: 35602903089245
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35602903089245_BA CK.rpl"
Processing MCU file: rm237__07.30.mcusw
[BB5,BB5 ALGORITHM] size: 14.49 MB
Supported Ids: 0103192101001101, 010C192101001101
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00020000-0007FFFF]
CMT FLASH,NOR area [00080000-000DFFFF]
CMT FLASH,NOR area [00100000-001FFFFF]
CMT FLASH,NOR area [00200000-0031FFFF]
CMT FLASH,NOR area [00320000-0105FFFF]
CMT FLASH,NOR area [01060000-01067FFF]
CMT FLASH,NOR area [01068000-0107FFFF]
erased in 1 min 23.313 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PMM_CONF block sent
CMT SBIF_CONF block sent
NOR: OK
Programming completed in 1 min 13.984 s
Processing PPM file: rm237__07.21.ppm_v
[BB5,BB5 ALGORITHM] size: 4.33 MB
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 4.62 MB
CMT FLASH,NOR area [01080000-0151FFFF]
erased in 24.859 s
NOR: OK
NOR: OK
Programming completed in 19.344 s
Processing CNT file: rm237__07.21.image_v_128
[BB5,BB5 ALGORITHM] page size: 128 K size: 5.01 MB
NOR page size in the phone is 128 K.
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 10.75 MB
CMT FLASH,NOR area [01520000-01FDFFFF]
erased in 1 min 19.469 s
NOR: OK
UCP page size is 128 K.
NOR: OK
Programming completed in 22.641 s
Total time for flashing process(boot+erase+write) was 5 min 47.422 s
Phone type: RM-237 (Nokia 3110c)
SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
Imei plain: 35602903089245-8
Product code: 0514949
Battery voltage: 4879 mV, current: 88 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 356029030892458
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
con này em thay flash . nạp lại mà không biết cách . đã backup rpl . cảm ơn mọi nguời trước . hjk
