máy tự nhiên mất nguồn , bật nguồn kim dong len rất đẹp, đây là log check;
MXKEY Serial: [FT SCR2000 0] - C0845DFF
Connection status: UHCI:HUB:USB 1.10 (Full-speed)
Driver: UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.24
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 00EC 2404 [Samsung ]
còn đây là log flash
Do not disconnect or abort this operation otherwise phone will be damaged.
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
Processing file: rm713_007.500
Downloading item CODE:hw_b1_rm713_r07.500.fls, num block: 3, size: 5.58 MB
Erasing area 0x00000000-0x00005FFE ...OK
Programming completed in 0.610 s
Erasing area 0x00800000-0x00BEFFFE ...OK
Programming completed in 1 min 9.563 s
Erasing area 0x00C5D000-0x00DFB6FE ...OK
Programming completed in 28.610 s
Checksum verified (0x423E)
Processing file: rm713_007.50mr
Downloading item CUST:hw_b1_rm713_007.50mr.fls, num block: 1, size: 5.07 MB
Erasing area 0x00100000-0x006120BE ...OK
Programming completed in 1 min 31.015 s
Checksum verified (0xCE93)
Processing file: rm7130_nai07.50mr
Downloading item CUST:hw_b1_rm7130_nai07.50mr.fls, num block: 1, size: 700.58 KB
Erasing area 0x00E60000-0x00F0E53E ...OK
Programming completed in 12.125 s
Checksum verified (0x1B11)
Total time for flashing process(boot+erase+write) was 5 min 18.922 s
ae xem rồi cho ý kiến giúp đỡ.
thanks all
			 x1_01 mất nguồn cần giúp
